I have the Acer S2W 3300u scanner and although I installed the drivers for Windows XP, it shows the error message "EXE application has encountered a problem and needs to close. We are sorry for the inconvenience" And then it prompts to send the error report to Microsoft. The scanner used to work properly so far. Do you know what might the problem be?
I have the same scanner and the drivers that came with the scanner don't work. Windows XP uses a generic twain driver that works, also most pictures viewer like XnView or Picasa uses the same. I'm using one called Wia-flatScanner_21 1.0(32-32).
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable...
(More)
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please give me the solution.
Recently installed Vista and will not scan. Says "No profiles have been created. To create a...
(More)
Recently installed Vista and will not scan. Says "No profiles have been created. To create a new profile use the Mail Icon in the Control Panel"
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is...
(More)
1.s2w 3300u software did not download what is the problem 2.If it was downloaded then after what is the process to use the scanner
