Question about Kitchen Ranges
Zanussi gas stove
Hi my gas stove takes so long to ignite, and im wondering why we need to hold the button so long? also the bottom of our pots are black after every use. Please help thanku
  • Anonymous Mar 07, 2008
    Same problem. I'm going to try the steps you described
  • odd job Apr 13, 2008
    black pots, orange flames, bad smell, tried to clean the burners and hob loads of times but still very bad please help, mums goin' sick
  • 725 Answers
Three problems with slow ignite on stoves.. first one is clean ignitors and burner caps. make sure that the caps and burners are correctly assemble. and make sure the stove is grounded correctly.. Do you flames have orange to yellow tips then there is a unburn carbon thst will form soot. soot productions is not achieving complete or efficient burning...again you may have dirty ot clogged burners..the flames should be all blue...let me know what you find out
Posted on Aug 31, 2007
I have a zanussi gas stove, and three of four hobs dont start
Posted on Jun 19, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Why wont my bottom oven heat up, it will ignite but wont heat,has the bulb anything to do with it,its blown HELP ZANUSSI ZCG660GXC LPG gas with electric ignition and clock.
The gas valve for the lower oven won't open after the igniter starts glowing. If there is no orange glow from the igniter, then it needs to be replaced.
Jun 19, 2015 | Zanussi Ovens
Hi, I have a zanussi gas oven, the fuse has blown a number of times. it then cuts off ignition and there is no gas in the bottom oven. not sure if any one can help because im left clueless...
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 27, 2015 | Zanussi Ovens
The gas range spark igniter does not work. I have a new part. How do I access the range top to replace it?
The whole top of the stove lifts off. You need to pull it out from the wall, unhook the gas, loosen and remove any screws that are on the back that hold the back to the top section. Open the stove doors and look up from the bottom to see if there are screws holding the top down, take those out and lift the top off. You can then access all the parts for the burners.
Oct 31, 2014 | Kitchen Ranges
Carbon residue on pots
There is an adjustment for correcting the air mixture on the gas line going from the knob to the burner. It usually is located at the point where the adapter nozzle enters the gas line going to the burner.
Aug 13, 2017 | Kitchen Ranges
Maytag gas stove model CRG9830CAE the oven will not work
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, the igniter needs to be replaced. Good luck.
Mar 27, 2010 | Maytag Kitchen Ranges
Stopped spinning and won't drain or do anything noe
hi unplug pull out machine if drain hose is at bottom of machine get bucket put hose in to it water will flow out when full raise hose water will stop repeat untill empty if hose is not at bottom tilt machine so counter top holds it get pot what ever wil fit under the drain fliter unscrew slowly not all the way to let out water once pot is full tigheten repeat untill water is out then open fliter clean look in make sure notthing is wraped around impeller if so take apart and put back same way
Nov 08, 2009 | Zanussi FJS1225W Front Load Washer
Need directions for Comet stove top rice cooker
Fill the bottom to the line with water. Put two cups of rice in the top and two cups of water. Put on stove top on high until lower water is boiling, turn to medium heat. For white rice check after about 20 minutes, if water is assorbed and rice is tender, fluff with a If it needs a few more minutes of cooking, no problem.
Brown rice will take about 45 minutes.
I have used my stove top cooker for at least 35 years...ordered it with box top and some money from Comet Rice.
Mar 09, 2009 | Kitchen Appliances - Others
Installing WB2x9154
For women from a woman's point of view: Most if not all the screws were hex head 1/4. Have appropriate tools. A socket set will work. I like my little cordless screw driver. You will also need wire strippers and two wire nuts, they say ceramic wire nuts and electrical tape. It is also a good idea to have a someone else there for safety sake. I tipped the stove back.
Take everything our of the oven. Take big screws out at the back bottom of oven. Lift bottom of oven and push toward the back of oven. (There is a lip at the front that oven floor slides unde). Be careful as there are sharp edges all over the place once this oven bottom is off. Next unscrew the screw at the front middle of oven that holds the long burner in place. Next pull the stove drawer out and set aside. Pull stove out just enought to put large juice cans under the front legs. Way at the back you will see where the burner comes down to the gas line. There are two screws holding it to the back of the stove, remove them. Next find the two wires that come from the igniter. Unplug them. Lift out the burner. Unscrew the two screws that hold the igniter on to the burner. Carefully put the new ignitor on the burner. If the new ends do not match the old ones or if they are shorter, cut the old ones off near the old ignitor. Cut the ends off the new ignitor as far from the ignitor as you can. Clean the ends off so that about a half inch of wire is bare. Put the old ends on the new wire so that you can plug them in. Hold the two like wires so that both bare wires are parallel and screw on the wire nut. Lay it parallel to one wire and wrap electrical tape around it so that it will not pull loose. Plug in the way it was originally. Put everything back together opposite of the way you took it apart.
Jan 24, 2007 | GE Profile Spectra JGBP79 Gas Kitchen...
Kitchen Ranges Logo
693 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
