Wfw9150ww water pressure switch location - Washing Machines
The washer faults during drain cycle. I have cleaned the filter. It is pumping fine with plenty of water flow but still faults out.
Maybe a short or oxidation.It could use other programm's drain cycle instead of the pre-set.You are washing cotton and it drains syntetics.
Mar 20, 2015 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Where is the water sensor located? Error message IE. Sensor might be faulty.
The water sensor is a pressure switch that sits on top of the drum and monitors the pressure of air in the drum. As water fills the drum, air moves out and this creates a pressure on the switch which works out proportionately how much water has filled the drum.
See video.
Washing Machine pressure switch
Sep 25, 2014 | LG Dishwashers
How do I adjust the pressure switch on my hayward h250 heater
The purpose of the pressure switch is to verify the pool pump is operating properly and water pressure is present in the heating chamber. When water pressure is not present, the heater control system is designed to not allow initiation of flame. The pressure switch is preset at the factory for deck level installations. When the heater is located below the level of the spa or pool, the pressure switch may require an adjustment to compensate for the no-flow static head.
CAUTION: The Hayward Pool Heater is essentially a furnace. A trained technician should be consulted to repair it. DO NOT OPERATE the Hayward Pool Heater without a properly functioning and calibrated water pressure switch. The pressure switch adjustment requires both the pool pump and the heater be operational. As a result, extreme caution should be used during this procedure since sources of energy can not be isolated during the procedure.
The following procedure is recommended to calibrate the pressure switch.
1. The water pressure switch is located behind the front service panel. The pressure switch is typically on the left side, above the burners.
2. Be sure the water filter is clean before making the adjustment.
3. With the pump and heater system switch on, carefully turn the pressure switch adjustment dial clockwise, until a click is heard from the gas valve.
4. Turn the adjustment dial counterclockwise 1/4 turn.
5. Turn the pump off and on several times. The heater should shut off immediately when the pump is shut off. If the heater fails to shut down when the pump is off, repeat the steps above until the pressure switch is properly adjusted.
6. If the adjustment process fails to produce proper results the pressure switch should be replaced.
Jun 22, 2014 | Hayward H Series Pool & Spa Heater...
Power when door open only wfw9150ww, other problems???
check for a short in the door switch,use a new switch and try versing polarity -sometimes works even if its wrong
Nov 06, 2013 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
Washer stopped working with error code f21
Generally F21 implies it takes to long to drain water. If you washer is not draining, it will not likely need a pressure switch but just a cleaning of the drain pump filter.
See images below (click image for zoom). If it is draining all the water nad F21 appears, then it likely has a pressure switch failure. The water level pressure switch part #8540224 is located under the main top. It is mounted along the right upper side panel as your standing in front of the washer.
In order to access and replace the water level pressure switch, remove the screws along the back of the main top and slide it back a little and lift it off. You will see the pressure switch (key#23) as shown in the image I added below.
NOTE: Disconnect the power cord from the power source before removing the top.
Once you locate the pressure switch, remove the pressure switch hose and wires. I added an image below with the instructions on how to access and remove the pressure switch. Note: There is additional information about the F21 fault code and some other information not pertaining to your fault code in the image below.
Hope this helps (remember to rating this free answer and leave one testimonial).
Sep 30, 2011 | Kenmore Washing Machines
Hi there Water overflowing, water does not stop on set levels Where is the sensor located
This is most likely the pressure switch. It has either malfunctioned, or the pressure switch hose is not connected. Usually pressure switches are location in the top console of the unit.
Mar 06, 2011 | Washing Machines
Keep geting F and H blinking on the screen
you could have a water valve problem,no water to machine,i've seen new water lines with shut offs built into the line that fail,put on regular burst proof water lines and the washer is fine, or a problem with the pressure switch located on right side of washer,take off the top of washer,you'll see a clear line going to the pressure switch,gently blow into the line and listen for a click,if it clicks the switch is ok, the last duet i worked on had same problem,just taking off the line from the pressure switch somehow reset the pressure switch and that's all i had to do it ran fine after that,also there is a flow meter located in between the water valve and the dispenser that can do this,hope this helps
Jan 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine over fills with water and will not agitate
If the washer overfills, it may be something as simple as a detached or broken air hose on the pressure switch. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
The pressure switch on top loaders is located behind the load level selector knob on the operator console. The pressure switch on front loaders will be located inside the cabinet, usually mounted along the back interior wall. In the case of certain Maytag front loaders, the pressure switch is actually located under the tub. The principles of operation on all of them is the same, though. They all have an electrical connection and an air hose that detects the pressure from the tub as the water level rises.
If the pressure switch is not able to detect the water level properly, it will not shut off and the washer will never begin the wash cycle. Instead, you get a tub overflowing on your laundry room floor.
Read through the link provided and let me know if you have any questions. I hope this helps you.
NOTE: Another source of an overflow could be the water inlet valve. This is usually a slow fill fill that you find when the washer is sitting idle over night. A quick test to determine the source of the problem is to unplug the washer. If the water stops - pressure switch. If the water continues to fill - water inlet valve.
Let me know what you find...
Aug 12, 2009 | Washing Machines
Ultimate Care II - water doesn't stop at the fill line, keeps filling to overflow and will not agitate
If you have questions, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
