Question about Ortho Dial N Spray Hose End Sprayer
Sprayer not sucking up liquid in bottle - Ortho Dial N Spray Hose End Sprayer
How do I open the sprayer to pour in liquid?
grab the handle put the bottle between your feet and turn the handle to the left
Jul 11, 2014 | Chapin 31430 Yard and Garden Tri-Poxy...
Why won't the bottle screw into my sprayer?
Its like putting a cap on a bottle.. If it doesn't go on its eigther a) cross threaded or b) the wrong cap or c) user error
Jun 05, 2014 | Scotts Miracle Gro Liquafeed Sprayer 6...
Aqua Pro RV Water System siphon kit, #27910 - i followed the instructions and installed the kit, valve right way, arrow pointing the right way. It does not suck the antifreeze out, it blows air or liquid...
The valve should be closed while siphoning from the antifreeze. This allows the RV pump to draw it from the jug instead of the holding tank.
You can not use city water or other pressure to move it.
If all else fails and you are using RV antifreeze imply place the antifreeze in the holding tank. turn the valve open and use the faucets normally until you get liquid out of them.
Come summer you can simply add 1/4 cup of non-phosphours bleach to every 5 gallons of water to clean and purify tour lines and tank again.
Oct 19, 2013 | AquaPRO AQUA PRO 27910 - Aqua Pro Siphon...
The liquafeed did not dispense much during about 10 minutes of spraying, (Only about 1/4"of Liquafeed was dispensed.
I'm sorry to hear about the problems you are having with your LiquaFeed Sprayer. Your water pressure needs to be at least 45 PSI. If your garden hose is longer than 50 ft, this can lessen the water pressure. If there is any foreign matter or crystalization on the bottle or the sprayer where the bottle inserts, this will need to be soaked in warm water, as it may be clogging the sprayer. With the bottle of LiquaFeed apart from the sprayer, squeeze the bottle to see if any product comes out. If none of these troubleshooting steps help, please call us at 877-465-5160, and we will be happy to assist you further.
Hilary @Miracle-Gro
Sep 19, 2011 | Scotts Miracle Gro Liquafeed Sprayer 6...
Rear suspension compressor don't stop burns compressor
YOUR AIR BAGS HAVE A LEAK, OR LINE. CHECK WITH A SOAPY WATER SOLUTION, MAKE SOLUTION WITH DISH WATER LIQUID SOAP. GO HEAVY ON THE SOAP. SPRAY WITH A BOTTLE SPRAYER ON THE BAGS AND LINES AND LOOK FOR BUBBLES. THAT WILL BE YOUR LEAK, YOU MAY HAVE MULTIPLE LEAKS, SO MAKE SURE TO CHECK THE ENTIRE SYSTEM.
Mar 03, 2011 | 2006 Cadillac Escalade
Gun will not feed fertilizer,
Here some things to check on your sprayer to make sure it is working properly. Is your hose 50 ft or less? Is your water pressure above 40 psi? When you turn the arrow to feed do you hear a slight clicking sound? Is the bottle tightly screwed into the container? Do you see any foreign matter or crystallization of the bottle or the sprayer? Do you see any particles floating inside the bottle if you hold it to the light? If you point the bottle toward a bucket can you squirt product out? Have your tried more then one bottle? If you have tried more then one bottle, your hose and psi meet the minimum recommendation and you don't see any foreign matter on the bottle or sprayer there is something wrong with the applicator. Please call us at 800-645-8166 we'll be happy to discuss this issue and see what we can do to assist you further. Lee Ann@SMG.
Nov 25, 2010 | Scotts Miracle Gro Liquafeed Sprayer 6...
Sprayer not working
Try these suggestions to get your machine working properly:
Make sure there is liquid in both the Tank-in-Tank and the SmartMix Bottle and check for spray through the upholstery hose. If the hose does not spray please check the following:
- Remove the belt access door and inspect the pump belt to ensure it is not broken, worn or stretched. You may also check the belt by turning on the power and watching the brush on the bottom of the machine. If the brush rotates the belt is not broken.
- Check for proper placement of the o-ring on the SmartMix Cap Insert (some o-rings are detachable and need to fit over the straw; others are molded to the cap).
- Check for liquid in the base of the machine where the SmartMix Bottle sits (SmartMix Reservoir). If there is no liquid in the reservoir, the neck on the SmartMix Bottle may be undersized, the cap will not make proper contact with the unit and the smart mix bottle will need to be replaced.
- Check for the black or red tank gasket on the SmartMix Bottle Cap and on the bottom of the Tank-in-Tank Assembly. If gasket is lodged in base of unit or has been lost, reattach gasket on auto-load or order new gasket if appropriate.
- Check the valves on the bottoms of the Tank-in-Tank and SmartMix Bottle to make sure water/solution will come through when the "x" valve is depressed. Bladder or SmartMix bottle may be empty or the valve may be blocked internally.
- Check if the small rounded window tabs on the top edge of the Floor Nozzle Window are locked in their mating slots on the base of the machine and not inadvertently lifting the tank up out of place.
If these suggestions do not solve the problem, contact a technician at a local BISSELL Authorized Service Center inspect your machine.
To locate your nearest BISSELL Authorized Service Center, please go to www.bissell.com. Click on the Customer Support tab near the top of the homepage and enter your zip code in the Service Center locator box to perform your search.
You can also locate a Service Center by phone, 24 hours a day, by calling 1-800-237-7691 and choosing option #1.
Jun 15, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Ortho Dial N Spray Hose End Sprayer Logo
136 people viewed this question
Top Ortho Garden Experts
raysaw
Nick Olsen
Are you an Ortho Garden Expert? Answer questions, earn points and help others
