Question about Micromark England Microcooler Plus Compact Refrigerator
The power was off for 2 hours and then unable to set alarm. Have not got the original information as to how to re-set. Model number Z9490A
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
Have bought a Technika DAB 109 CRF radio and no instructions. 1. how do I tune it and SAVE to presets 2. How do I set the alarm? Thank you
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Feb 20, 2011 | Audio Players & Recorders
I have an i-connex ipod docking station model 583258 with clock/alarm and radio but I have been unable to set the clock as I have mislaid the instructions. I am usually pretty good at working these things...
1. Fit the DC power and switch on the appliance by pressing the standby button 2. To set time, press CLOCk button to alternate between 12 and 24 hour format. 3. Press and hold CLOCK button until the set hour flashes on display 4. Adjust time using SKIP/SEARCH 5. Press CLOCK to set the time, same procedure for minute
To set alarm
1. Press AL SET 1/OFF 1 button, then press and hold the same button until the alarm time starts flashing 2. Press SKIP/SEARCH to to set time as above
Jan 17, 2011 | Audio Players & Recorders
I need the instructions for alarm clock model number cc208s
Please try this....
Setting the Clock
1. Press and hold the Clk Set Button.
2. While holding the Clk Set Button, press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute.
3. Release the Clk Set Button to set the time.
Setting the Alarm
1. Press and hold the Alm Set Button.
2. While holding the Alm Set Button , press the Skip/Search/Hour/Minute Buttons to adjust the hour and minute for the alarm time.
3. Release the Alm Set Button to set the time.
4. Adjust the Auto/Off/On Button to Auto.
5. Adjust the AM/FM/CD Switch to the desired function for the alarm, or reduce the Volume Dial to "Buzz" to wake to the unit’s buzzer.
Cheers!
Jul 13, 2009 | Audio Players & Recorders
Alarm not working properly for model # cks3020 suffix#b
http://www.emersonradio.com/owners/SmartSet%20Series/CKS3020_072706.pdf Copy this web link and paste it into the address bar of the browser. This will take you to Emerson customer support web page that contains a pdf copy of the owners manaual for your model Clock/Radio. Here you can find the correct procedure for setting the alarms for the Clock/Radio. If the alarms still do not work correctly. You will have to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and take out the internal battery. Let the Clock/Radio set for at least 1 hour without any power source. Then reinsert the battery and plug in the Clock/Radio and see if the functions return to normal. If not you will need to call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of you Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Feb 22, 2009 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio setting for everyday alarm
You will need to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio and remove the internal battery (CR2430). Let the Clock/Radio set without any power source for at least 2 hours. Then put the internal battery back in the Clock/Radio and plug it in to the a/c outlet. Test to see if the Clock/Radio functions have returned to normal. If the function have not returned to normal, you will need to replace the internal battery. Then let the Clock/Radio again set with out power for a period of at least 2 hours. after a 2 hour period, put the new battery in the Clock/Radio and Plug it into the a/c outlet. Test the functions to see if the microprocessor has reset to normal operation. If you are still having a problem with the Clock/Radio's operations , you will have to give the Emerson customer support a call. The Telephone number for the Customer support is 1-800-898-9020. You can call them between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you fix the problem with the alarm in the Clock/Radio.
Jan 30, 2009 | Emerson Smartset Clock Radio
Sharper Image Projection US Atomic Alarm Clock (model number OQ311)
try looking up the manual on the model number you might find it online. I have the maual for this model.
Jun 10, 2008 | Audio Players & Recorders
Alarm not working
Sorry it took so long to reply to your problem.You must try to reset the Clock/Radio's microprocessor. To do this you must disconnect the Clock/Radio from the A/C power source and remove the internal battery. Let the Clock/Radio set without any power source for about 3 hours. This should completely drain all the power from the microprocessor. After this is done, reinsert the internal battery and plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal. If they do not return to normal. Unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace the internal Battery (CR2430). Let the Clock/Radio again drain all the power from the microprocessor. Insert the new battery and Plug the Clock/Radio into the A/C power source. The Clock/Radio's functions should return to normal.If you should still be having problem with the functions of the Clock/Radio, you will need to call Emerson Customer Support. The telephone number for Emerson Customer Support is 1-800-909-1240. Call them between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance with your problem. I hope this information help you with your problem. Thank you for using FixYa and have a nice day!
Oct 26, 2007 | Emerson Smartset Clock Radio
Micromark England Microcooler Plus Compact Refrigerator Logo
20 people viewed this question
Top Micromark Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Micromark Refrigerator Expert? Answer questions, earn points and help others
