Question about Vizio VSB210WS Soundbar
I have a Vizio VHT215 sound bar. Was working fine. Turned it off and when we turned it back on the next time the power will not stay on. Tried resetting to no avail. Any suggestions?
dsacco86
  • 1077 Answers
SOURCE: No Power to a Vizio VX32L
My best guess is to check for blown fuses or the power board when bad inside the TV.
If that doesn't work, looks like you'll have to pay a repair shop to find out what's really going on.
Sorry I can't help you further.
Posted on Feb 03, 2009
SOURCE: vizio vx42l hdtv back light
Vizio VX42L has sound but no picture, tried other connections
Posted on Apr 16, 2009
  • 10 Answers
SOURCE: Vizio won't turn off
This could be a mainboard problem. Sometimes one of the fuses may be bad and may freeze up causing the TV to not be able to power off.
Posted on May 23, 2009
  • 13 Answers
SOURCE: The LCD screen is dark with no sound or picture when turned on.
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Posted on Jan 22, 2010
kidsasuke
  • 121 Answers
SOURCE: no sound and no picture
It may well be the power supply. Filter capacitors have a nasty tendency of blowing, as well as voltage control ICs. If the filter blows, you end up with a shaky DC signal that can't be effectively used by digital components (which make up about 80% of modern TV circuits). If you're within warranty/exchange then go for the manufacturer. If not, and you're comfortable with opening these things, then you can carefully (after unplugging and allowing it to discharge) take a glance inside. If any capacitor(s) are visibly blown out, then there's your problem.
Posted on Jun 03, 2010
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
Uverse remote
Programming procedure is too much to type in here by this window, and is not practical. If you wish to get details; check the site linked here. It have set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 18, 2014 | Televison & Video
Vizio downloads firmware every time it is turned on
Firmware corrupted. A reinstallation is necessary. Contact any service technician.
Mar 04, 2017 | Vizio XVT553SV 55 in. LCD TV
How to get my vizio soundbar programmed to charter remote?
I have a Charter Universal Electronics OCAP 4 remote Control and a Vizio VHT215. I was able to get on/off and volume control functionality using code 32454 for the Aux device.
Jan 24, 2012 | Vizio High Definition Sound Bar
Need dish code for remote for vizio soundbar
Hey there, this is Cheri Torres with DISH Network customerservice. I wanted to see if I could help you with the question you posted aboutthe Vizio sound bar. I was unfortunately not able to find any codes for theVizio sound bar. Another option you can try is running a channel scan to findyour code that will work best to control your sound bar. I hope that theseinstructions are useful to you. If you have any further questions or concernsplease feel free to post back here or email me at Cheri.Torres@Dishnetwork.com.
Remote: All Remotes (except Basic)
    1. With the desired equipment on, press and hold the correct Mode button until all mode button back lights illuminate, then release.
    2. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button
      • Press 0 for a TV
      • Press 1 for a VCR/DVD
      • Press 2 for any other device.
      Then Press STAR (*)
    3. Press the Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, the equipment will power off.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Dec 27, 2010 | DISH Network IR Remote Control
WORKED FINE WHEN TURNED OFF, THEN NO SOUND WHEN TURNED ON
1. I would first make sure that correct "INPUT" setting is registered.
2. Try a different input source such as VCR, DVD or CD.
3. Connect a pair of audio RCA cable to all the VIZIO set's audio inputs one at a time and touch the center tip while the set is powered ON and the input is set to the corresponding seting. If audio circuit is OK you should hear a hum with at least one of the input settings..
4. If still no audio, then it maybe the audio circuit board needs to be checked.
May 15, 2009 | Vizio L32 32 in. LCD HDTV
TV flickers when turned on. This affects both sound and picture contantly and quickly going in and out. Amber light is on when TV is off, and white light is on with TV. I turned on the TV and it was...
this TV has built-in MOV's, the exact same thing you find in the surge protection bars... perhaps one of those has done it's job and fried OR something totally different is working a mess on the PwrSup board, like the 450V cap that is always powered at least under 150V while the set is off and pluged in with amber light.
If you don't know you way around PWM electonics your next step may be to call Vizio. Good luck on getting this resolved to your satisfaction for less than $300.
Feb 20, 2009 | Vizio GV42L 42 in. LCD Television
Vizio VSB210WS Soundbar Logo
52 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
