Question about Muratec Office Equipment & Supplies
Muratec scanning error - not able to transmit confirm setting
Dear Sirs/Madams, I have a Muratec MFX-1930 network multimachine (printer,scanner,copier,fax). Everything is working fine i can print, fax, copy and scan. My problem is the scanner scans to internal...
Unless your machine is connected via ethernet cable.( NOT USB.!!) you will not be able to scan directly to a Network folder.
Anotherwords..you can scan to a Network folder if its an RJ45 cable but NOT if your using USB.
If you are using ethernet the machine should have come with the appropriate software...if you have lost it you can get it at www.muratec.com .
**If you are using USB...installing the Network software will NOT make it scan to folder.
Apr 01, 2011 | Muratec Copier
#R.4.2 ERROR CODE - WHAT DOES IT MEAN
Error code R.4.2 means, either the line disconnected before transmission or the transmitting fax
machine needs maintenance.
Jan 07, 2011 | Muratec F-520D Fax
Not receiving - reports say line busy, I think I inadvertently set something I don't want. Can transmit fine.
Please be sure you have the phone line from the wall plugged into the "line" plug on the fax machine and not the "phone" jack
Oct 07, 2010 | Muratec F360 Plain Paper Laser Fax
I am attempting to set up a Muratec MFX-1430 printer for a client and it does not seem to be communicating via the network. I have it plugged directly in to the Belkin wireless router that the desktop PC...
IF YOU HAVE THE INSTALLATION CD THAT WAS SUPPLIED WITH THE MACHINE THERE IS A "MANUAL SECTION" IN IT THAT EXPLAINS HOW TO SET UP THE INSTALLATION.
iF YOU DONT HAVE THE CD YOU CAN DOWNLOAD IT FROM MURATECS WEB SIT AT THIS FOLLOWING LINK http://www.muratec.com/new/support/manuals-for_muratec0o34534021023994938849.asp
Oct 01, 2010 | Muratec MFX-1430 Copier
Muratec F-300
T2.1 means bad phone line.
Do.7 means the STOP was pressed during dialling
DO.2 means the remote machine is busy.
Download manual from Muratecs we site(FREE)
www.muratec.com
Jun 26, 2008 | Muratec F-300 Fax
Problem scanning on MFX-1430
I am not sure why all scan to email is deleted, but you cant use scan-to-email or any of those scanning features using a USB anyways. Must be connected to the network
If connected by USB, you can download some twain scan utility (purchase one or download free one online) on your computer and install/set it up to use the Muratec as the scanner. Anytime you want to scan, open and use that utility.
Jun 22, 2008 | Muratec MFX-1430 Copier
Error message "003"
You can call muratec and they will help you troubleshoot. 469-429-3300 for Muratec.
Please don't forget to rate the answers you recieve.
Dec 18, 2007 | Muratec - MFX-1300 Copier
MURATEC F-520 ERROR CODE 04
This code relates to a Drum Cartridge Problem.
Check the cartridge is installed correctly or at least try another drum cartridge.
Oct 03, 2007 | Muratec F360 Plain Paper Laser Fax
Jounal Entry Dates
Most machines will only keep a certain amount of transactions in memory. Your fax that you are looking for is probably over the amount of transmissions kept in memory. One suggestion, if the fax was a long distance number, you could check your phone for that number. You also might want to set your machine to print a confirmation report for every fax sent and staple it to your fax for further reference.
Jun 25, 2007 | Muratec F320 Plain Paper LED Fax
49 people viewed this question
Top Muratec Office Equipment & Supplies Experts
Kyocera HP Expert
Ben
Ben
Adorjani Laszlo
Are you a Muratec Office Equipment and Supply Expert? Answer questions, earn points and help others
