Question about GE Spacemaker 18" Built In Dishwasher - GSM1800JBB
Ge gsm1800jbb dishwasher overfills to the point that water leaks from the door.
  • 1462 Answers
SOURCE: Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Posted on Apr 15, 2007
SOURCE: GE Dishwasher GSD4020Z07BB is leaking water and doesn't drain
yes...mine leaks at the door base as well
Posted on Jan 30, 2008
gypsycat00
  • 224 Answers
SOURCE: Leaking at the bottom of a GE dishwasher
If it's under a year old, it's under warranty, just call 1-800-GECARES and they'll send someone out to replace the door gasket. If it is over a year old, you need to replace the door gasket. There are small black lines that extend beneath the door into the body of the dishwasher that will be replaced when you install the new gasket. This will seal the door so that you no longer have anymore leaks.
Posted on Jul 11, 2009
thunderalley
  • 432 Answers
SOURCE: water leaking underneath our GE GSD2030Z01 WW dishwasher
lose hose clamp or bad motor seal, or bad seal
Posted on Sep 13, 2009
  • 74 Answers
SOURCE: My GE Nautilus dishwasher leaks. Water comes out
it should be replaced.
Posted on Oct 24, 2009
Does not drain properly . It leaks through the door.
The leaks through the door problem is caused by an overfilled tub. Remember, these dishwashers aren't bath tubs. Those seals are only designed to keep water from splashing out, not for completely filling the dishwasher with water. These problems are both caused by the slow drain, and can usually be fixed quite easily by removing and cleaning the strainer screen and using a wet/dry shop vacuum to **** out the debris underneath. If your shopvac is powerful enough it will also clean out the water pump.
Replace the screen and try again.
Mar 05, 2010 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Jan 23, 2010 | Dishwashers
I have ge dishwasher thats 3 years old and I'm having problems with it leaking from the bottom of the door. I replaced the seal once but I can't tell what else the problem could be. Any suggestions?
it could be overfilling. check the overflow float inside. if it is stuck down, the water level will get to high. the seal is not meant to be under water. it just stops splashing water. if it moves freely, it is okay.
Oct 26, 2009 | Dishwashers
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
I have water leaking under my dishwasher (probably right in the middle). I put a paper plate underneath to catch the water during the cycle. There seems to be some "soap scum" on the bottom where it is...
Hello there
Here is several ideas that will help you
also (fyi) type in search engine how things work and once it opens just enter dishwasher and it will bring you to the dishwasher section ok?
here it is
Dishwasher is leaking water
  • Inspect the seals for the main tub, float, heating element and blower diffuser
  • Check for overfilling
  • Inspect the water and drain hoses
  • Inspect the door gaskets
  • Check the water inlet valve
  • Check the pump
Water or soap leaks around the door
  • Make certain that your detergent is intended for dishwashers. Do not use liquid dish soap.
  • Inspect the door seal gasket
  • Check the door latch
  • Inspect the door hinges
  • Inspect the spray arms for damage
Water drains through the air gap into the sink
Sep 16, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch sgs5312gb leak
More than the door seal, check the water level is not stuck down or sinking. If the appliance is leaking from the door, this is often because of overfilling. If the machine is not overfilling, then replace the door seal.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 04, 2009 | Bosch Dishwashers
Dishwasher leaking water.
  • Check the pump
Hope it may help you;
Regards,
VOTIT
Sep 25, 2008 | Frigidaire 24 in. PLD2850 Built-in...
Dishwasher leaking on florr
Hi.
It could be:
a dirty door seal
a clogged pipe on the pressure sensor causing it to overfill
a genuine leaking hose
Much depends on where it is leaking from. The door seals can be cleaned with a detergent laden cloth, hard grime removed with a plastic scouring pad or a blunt knife (with care)
A clogged sensor pipe needs to be removed and cleaned out - access will most likely be from beneath. While you are there you can check the hoses for leaks too!
As a starting point I would put a kettle or two of very hot water and a generous dose of detergent into the machine and try to let it clean itself. While it is doing that try to spot where the leak is. There may not be one if it was overfilling.
I hope this helps.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please add a comment with more details so I can try to help you further. Cheers, D
Jul 01, 2008 | KitchenAid KUDS01DJ - Multiple Color...
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
GE Spacemaker 18" Built In Dishwasher - GSM1800JBB Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
