Question about JVC AV-36F702 36" TV
JVC AV-29PRO in standby only - JVC AV-36F702 36" TV
Blinking light onjvc 32432 tv no power
How many times the standby light blinks at a time of switch on? Count it. These blinks are fault indications [codes]. Count it. If you wish to get more details about the blinking codes to JVC brand TVs check this site.
Feb 09, 2013 | JVC AV-32432 32" TV
JVC AV-32H5SK Intermittently goes to standby when first switched on.
checyour power supply and earting properly.
also change your adapter mthen try
Sep 29, 2008 | JVC Televison & Video
JVC TV AV-28R47SK - very slow to switch on and sticks in standby
your lamp is going bad you need to buy a new one
Mar 29, 2009 | Televison & Video
JVC AV-36260 No Sound No Picture Red Light Blinks Copntinuously
Try this blog I found on this site. I have the same model and problem with my JVC TV set and I was able to fix it for 2 bucks at home by myself.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 07, 2009 | JVC AV-36950 TV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Av 32d305 JVC tv
has the problem solved a little yet?
Oct 31, 2008 | JVC AV-32D305 32" TV
Goldstar TV (unknown model)
tv has a power supply fault requires service
Oct 22, 2008 | JVC AV-27530 27" TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
How to repair
check if it is plugged in,power button is pushed and standby led is lightening (red or green).
May 13, 2008 | JVC AV-27230 27" TV
TV, i plug it in, turn it on, no image, "on timer" light comes on.
If you dont hear a click theres a problem in the standby power supply. if you do hear a click theres a problem in the Main power supply or sweep supply. Get a good tech to look at this for you if your not a tech. Good Luck
Aug 07, 2006 | JVC AV-27D302 27" TV
JVC AV-36F702 36" TV Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
