Question about Zanussi ZDC37100W Electric Dryer
Zanussi 37200w says tank id full when its empty
4 Suggested Answers
BingoDabbers
  • 102 Answers
SOURCE: ZDC5350W 'full tank' sensor
Look for the sensor in the tank. If it is a float sensor then check it is not stuck. If it is a probe then clean the insulator.
Posted on Oct 06, 2007
SOURCE: Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Posted on Jan 31, 2009
carl_brou304
SOURCE: zanussi tumble dryer stops every 3 minutes
I fixed this problem by cleaning the float in the water tray at the bottom left of the machine. You need to remove the left side panel first. At the back you will be able to see the float that senses whether the reservoir is full through a small window. It should move up and down freely. If it doesn't then you will have to remove the reservoir cover. There is a small screw to remove, then ease the two spring clips so that the reservoir cover is released. You can now remove the float. Give it a good clean and clean inside the reservoir too. Double check that the switch is functioning correctly. You can hear it click.
Posted on Apr 09, 2012
Zanussi ZDC8202P-WH. Only 10 days old. It stops halfway through the cycle with the 'water tank full' indicator coming on, but tank doesn't need emptying. It is in properly.
Return it back to the place of purchase and buy a different brand of dryer. Try Whirlpool or Sears Kenmore. You should have much better luck with these name brands.
Dec 01, 2015 | Zanussi Dryers
My Zanussi ZDC 37200W has no power
Go to the self help section of repairclinic.com Enter you model number for specific trouble shooting advice on your appliance.
May 14, 2015 | Zanussi Dryers
My new tumble dyers stops after 10 minutes telling me the water tank is full, when its empty
Since it is new, I would call the mfr and have them look at it. It is under warranty isn't it?
Jan 11, 2015 | Zanussi Dryers
My zanussi dehumidifier's tank full light comes on and the machine stops wehen the tank is practically empty. Is there any easy way to fix this problem myself
Most dehumidifiers have a switch near the top right of the tank or left. When the tank gets full it tips out a bit and trips the switch to turn it off and light the indicator. Make sure the tank is sitting properly as I have done this before, and had the same problem, or check and adjust the sensor(if possible) to fix the problem. The tank not sitting right can cause it to trip the switch with a mostly empty tank.
Nov 22, 2014 | Zanussi Washing Machines
Why does the condenser tank full light come on even though its empty
Hello, before call the specialized service try this:
Turn off and unplug the dryer from the main supply.
Open the main door of the dryer and with your hand attempt to move the drum up several times.
Aug 10, 2014 | Zanussi Dryers
Zanussi tumble dryer stops every 3 minutes reporting full tank even though the tank is completely empty. any ideas to solve this annoyance? Thanks
Nov 27, 2009 | Zanussi ZDC5355W Electric Dryer
1986 f-250 duel tanks fuel gauges not registering right
id say either your sender unit is nackered or you have a bad earth to the body
Feb 05, 2009 | 1986 Ford F 250
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Zanussi Tumble Dryer
Sounds like the condense pump is bad. Replace it, or look if there is lint in it. ;)
Dec 30, 2007 | Dryers
Oct 06, 2007 | Zanussi ZDC5350W Electric Dryer
Zanussi ZDC37100W Electric Dryer Logo
56 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
