Question about SVP FS1000 Film Scanner
Software cd installer
Download installer
I have a printer hp deskjet 1050 J410 i can't install any thing how come even can't find this printer onlines why not ?
Solution: Delete the printer error icon, and then install the HP software Follow these steps to remove the printer error icon, and then install the HP software. Step one: Delete the printer error icon Follow these steps to remove the printer error icon from your list of devices and printers.
  1. On the Windows taskbar, click the Windows icon (c01367376.gif ).
  2. Click Devices and Printers .
  3. Right-click the printer error icon (c02439149.gif ), and then click Remove device .
Step two: Install the product software Use the following methods to install the HP software with a USB connection. Figure 1: USB cablec01704933.gif CAUTION: Do NOT connect the USB cable now. Wait until the on-screen instructions prompt you to connect it. HP recommends using a USB cable that is less than 3 m (10 ft) long. Should I install with the product CD or download the software? Don't worry if you don't have the product CD! You can download the most current software available for your product from the HP Web site at no cost. The following information might help you decide which installation method to use: CD Download The CD provides a quick and easy installation method. If you do not have a CD, you can download the software you need from the HP Web site. CD installation might not work if you are installing the product on a computer running a newer operating system that released AFTER the HP product released. Even though it takes more time than using the CD, downloading the latest software can help avoid installation issues.
Downloading is the recommended method if your computer operating system released after the HP product released. The software on the CD is current to the date of the product release. The software that you can download from the HP Web site is the most current software available for your product. HP often updates software and drivers AFTER the product and CD release to the market.
Step one: Download the software Follow these steps to download the product software and save it to your computer.
  1. Disconnect the USB cable from both the product and the computer (if you already connected it).
  2. Turn the product on.
  3. On your computer, open a new window to browse to the Get Software and Drivers page: Right-click this link, Get Software and Drivers , and then click Open in New Window .
  4. If prompted, type your product number, and then click Next . You might also need to click your model in a list of similar products.
  5. Select your operating system, and then click Next .
  6. Read through the minimum system requirements and additional instructions. You can also click View directions (c01647276.gif ) for complete download instructions.
  7. Click Download .
  8. If the File Download Security Warning window displays, click Save , and then browse to the location on your computer where you want to save the file.
  9. Click Save . The software downloads to your computer. Hint: Make a note of the folder where you saved the file, in case you want to install it at a later time.
Step two: Install the software During the installation, the Basic Device Software and Product Help are required to enable full product functionality. HP also includes valuable software to help you get the most out of your product. Follow these steps to install the downloaded software.
  1. When the download is complete and you are ready to install the files, click Open Folder , and then click the downloaded file. The file name ends in .exe . NOTE: If you closed the Download Complete screen, browse to the folder where you saved the .exe file, and then click it.
  2. You can accept the default place to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. When the Install Wizard starts, follow the on-screen instructions to install the software with a USB connection.
Jan 10, 2011 | HP PSC 1410v All-in-One Printer
My monitor hpw1858 recommends settings 1366x768-60Hz, I can't find it in the PC settings . In options Screen resolution dosen't exist this setting. Therefore, please advise me on what to select, because I...
  1. This document describes using and adjusting flat panel monitor model w2338h.
Installing drivers Install the software from the CD, or download them from the Internet as follows: Installing drivers from the CD To install the monitor driver from the CD:
  1. Insert the CD in the computer CD drive. The CD menu appears.
  2. Select the language.
  3. Click Install Monitor Driver Software .
  4. Follow the onscreen instructions.
  5. Restart the computer.
  6. Check that the proper resolutions and refresh rates appear in the Display Properties window in the Control Panel.
Installing drivers from the Web To download the latest version of drivers and software files from the HP Support Web site:
  1. Go to the HP Support Web site
  2. Select the country/region.
  3. Select Download Drivers and Software .
  4. Enter the model number of the monitor, for example w2338h . The software download pages for the monitor display.
  5. Make sure the system meets the requirements given.
  6. Download and install the driver and software files by following the steps on the screen.
  7. Techbelkin please rate me
Nov 03, 2010 | Computers & Internet
How to install so that we can print
Method one: Install the software with the product software CD If you have the product software CD, follow these steps to reinstall the software. If you downloaded the software, skip to Method two: Reinstall the downloaded software .
  1. Insert the product software CD into the computer’s CD drive. The software installer starts automatically.
    • If the Install Wizard does not start automatically, click the Windows icon (c01319360.gif ), click My Computer , and then double-click the CD drive. On the CD menu, click Install Printer Driver .
  2. Follow the on-screen instructions to complete the software installation, and then proceed to the next step.
  1. Browse to the folder where you saved the downloaded file, and then click it. The file name ends in .exe .
  2. You can accept the default location to save the files. Click Next , and then wait while the installer extracts the files to prepare for installation.
  3. Follow the on-screen instructions to complete the installation, and then proceed to the next step.
Step five: Re-enable startup programs
  1. Click the Windows icon (c01319360.gif ). In the Start Search box, type msconfig , and then click OK . The System Configuration Utility window opens.
  2. Click the Startup tab.
  3. Select the check box next to programs that should run when the computer is turned on (see the notes that you took earlier in this document). CAUTION: Do not disable any Microsoft services.
  4. If no changes should be made to startup programs or services, click the General tab, and then select the Normal Startup check box.
  5. Click Apply , click OK , and then click Exit without restart .
Step six: Install the HP software update
  1. Right-click this link, HP Critical Update , and then select Open Link in New Window .
  2. Thoroughly review the information on the download information page, and then follow the on-screen instructions to download and install the software.
  3. Restart the computer and the product.
Jul 20, 2010 | HP DeskJet D1460 InkJet Printer
HP DJ F370 CD Image
You can burn the software on a CD, you don't need the image. The old HP software and driver is likely causing the system to hang; remove all the HP software, remove the printer from the printer list, and then install the printer as a first time install.
It will install from a folder once you remove the old HP software
Jul 23, 2009 | HP Office Equipment & Supplies
Lost install CD for Canon PIXMA MP160
If you do not have the software, you need to download the software from one of the following locations:
Official Canon Drivers and Software
Canon USA:DRIVER & DOWNLOADS
After downloading is finished, unplug the printer USB and run the software that you downloaded.
The software installer will tell you when to connect USB.
Mar 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
How to Recover/download Software CD for NV-GS35; Panasonic VFF0264-A; MotionDV STUDIO 5.3E LE for DV
I have panasonic Digital video camera model NV-GS25GC
I need driver for windows7 for it thnk you
Dec 24, 2008 | Panasonic NV-GS25 Mini DV Digital...
Lost my webcam installation cd
Depending on you camera model, go to http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=gb,en
select you model, then d/l and install the software.
Please repost if this helps,
MM85
Jul 27, 2008 | Logitech Webcam
Installation CD lost
The driver and the CanoScan Toolbox can be downloaded. Unfortunately, the bundled software is not available for download. Try contacting the Canon Support Center to see if they can send you another.
May 06, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
How to install my printer without the CD installer
you can download the software, don't worry i have provided the Download option.
For Windows XP - Click here to Download
For Windows Vista - Click here to Download
Download the software and Install.Always Glad to help.
Thanks
Riz
Apr 21, 2008 | HP DeskJet 3940 InkJet Photo Printer
it s not working,....when i click to insatall..it extracts 4 a second n then an error occures..,,it s not working....
Jun 18, 2007 | Panasonic NV-GS35 Mini DV Digital...
SVP FS1000 Film Scanner Logo
Top SVP Office Equipment & Supplies Experts
Jay Plesset
Are you a SVP Office Equipment and Supply Expert? Answer questions, earn points and help others
