Question about Ovens
Fan not working - Ovens
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Ovens Master
  • 102,366 Answers
What make and model oven?
Posted on Jul 31, 2013
Oven and works but fan not working bush ad66tb
The fan could be greasy and "stuck", you'd have to take it out to check.
Unfortunately replacement fans are quite expensive:
Bush AD66TB Fan Motor 230V 23W Cl
Jul 15, 2016 | Ovens
I have a double whirlpool fan oven. The fan doesn't always work, seems to stick. What do I need to do to get it working? We've had it less than 3 years but I've never cleaned it. Is this why it doesn't...
Do you mean the fan inside the oven box in the back wall. This is the fan for the Convection bake etc. If so this is how it works..
a) Bake feature - that fan does not come on
b) Convection bake - that fan comes on during bake cycle
So that fan works for several features but not for all. It helps to circulate the hot air inside better for a more even, fast bake.
Do you mean the fan in the control board area. It is there to get the hot air trapped in the oven walls out. Not the heat inside the oven bake box area. This fan works differently depending the model and/or brand. Some models fan works from the time you start. Some models fan comes on only when that area reaches a certain high temperature.
Mar 01, 2015 | Whirlpool Ovens
My oven fan is not working
What fan is not working. There is the convection fan, chassis fan and mag fan. Please reply with what fan is not working.
Jun 14, 2012 | TurboChef TORNADO Electric Oven
I have a neff fan built in oven everything is working except the fan is it a matter of just replacing a new fan?
Make sure there is a supply to the fan before attempting to replace it, if there is and the fan does not work, then replace it.
If the fan element is getting hot, but the fan is not working, then you need to replace the fan motor assy.
It is a fairly straightforward repair, but remember that the fan blade assy is secured by a left hand thread, so unscrew the nut clockwise as though you were tightening it, holding the fan blades as you do it.
Jun 22, 2011 | Ovens
I have a fan forced chef classic wall oven and the fan has stopped working....why ould this have happened/
There has several reasons the fan could have stopped working:
-It is possible the fan wiring/connections have become loose or unplugged
-It is possible that the fan motor has worn out or become jammed over time due to debris
-If you recently cleaned your oven, the fan could have stopped working if it came into contact with any caustic oven cleaner.
Hope this helps.
Feb 28, 2011 | Ovens
Oven fan not working
If you select the function on the selector switch which turns both the fan forced fan and the oven element on at the same time and the fan does not work, but the oven element does then the fan forced fan is faulty and requires replqcement.
Feb 25, 2011 | Stoves 720EF Electric Double Oven
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
Oven fan wont work
You need to determine if you are getting a mains feed to the fan motor, if not, then you need to trace the wires bcck to source and work from there,
If you are getting a 240 volt supply, then the new fan is faulty.
Hope this helps you.
Dec 15, 2009 | Ovens
Fan stopped working
If it is heating without the fan working, then there is probably something wrong with the fan.
If there is no heat as well as the fan not working, then check that the timer is set to manual and not on auto.
To access the fan and heater, remove the rear panel inside the oven, spin the fan by hand,it should be completely free,
If it is not, then it needs replacing.
Plz rate my solution.
Thanks
Jan 02, 2009 | Belling XOU252 Electric Single Oven
Neff 1861 oven fan stopped working
Fitting new bulb would not cause fan to stop working.
If it is getting hot, then there is something wrong with fan, try spinning fan by hand, it should be free, and continue to spin under it's own momentum.
Hope this helps.
Thanks.
Dec 29, 2008 | Neff B1861 Single circotherm super...
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
