Question about Saeco Espresso Italiano (00566)
What is wrong with the machine, when the red wrench appears?
Why does my machine a red wrench & the number 3, what's wrong with it?
Here is the Troubleshooting for the "Red Wrench" problem:
Turn the machine off . After 30 seconds, turn it back on. Try this 2 or 3 times. If the machine does NOT start, contact an authorised service centre.
The manual is available at: http://download.p4c.philips.com/files/h/hd8838_02/hd8838_02_dfu_eng.pdf
Jun 03, 2014 | Saeco Syntia Espresso Machine & Coffee...
I have a Saeco Syntia and a Red Wrench with the #14 came on the display. I have turned on and off and now the yellow thermostat symbol comes up. you can feel it heating up but it does nothing else.
need to tell me when the wrench appears ,at start up ? YES? then most likely "over pressure valve" is broken and machine needs to be serviced by service center to replace the plastic part with a metal parts ,Stop using it or the leaking water will damage the system .
Jan 18, 2014 | Saeco Syntia Espresso Machine & Coffee...
Stuck Needle Plate Setting Knob
Spray it with Liquid Wrench (NOT WD40!!) and let it set for a day or so.
Nov 03, 2012 | Janome MyLock 644D
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
My imagistics c235 has a red wrench light on. Does anyone now how to clear this?
The red wrench indicates a serious problem. Does it show any error codes ?
Mar 05, 2011 | Office Equipment & Supplies
Starts ok wrench appears heats ok wash cycle pressure strong at first then fades wrench appears -p2 -cleaned screens and checked spray arms .incoming water pressure 20 psi whats wrong ?
Check the spray arm. Machine water pump. After this pump pressure
builds up to the spray arm. Rubber hosejunction inside the wash tub.
This place gets connected to the spray arm system.
You can see this when you draw the tray for loading vessels.
Slowly push it and watch the junction where this gets locked into the
rubber hose mouth inside the wash tub. There should not be any
water pressure leak.
Sep 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I need a website to buy parts for my 1/2" drive nitrocat1000RG
GO TO CHIGO PNUMATIC .COM/CLICK ON IMPACT WRENCHES THEN AUTOMOTIVE WRENCHES THEN VIEW FILE(IN RED) THEN IT SHOULD SHOW PARTS LIST.HOPE THIS HELPS RATE THIS ANSWER.
May 16, 2009 | Chicago Pneumatic CP7750 1/2" Air Impact...
Copier will not operate due to wrench symbol
Hi the the wrench symbol appears when its time for maintenance depending of the type of service needed the copier will shut down, the only why to over come this is to call your service provider for maintenance they will replace what ever parts and or sevice thats needs to be done, they will then enter the code that is need to reset the wrench symbol..
Good Luck
Jan 27, 2009 | Panasonic FP-7735 Black and White Copier
Saeco Espresso Italiano (00566) Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
