Question about PPG Olympic Premium Deck Care Sprayer
Olympic deck sprayer parts - PPG Olympic Premium Deck Care Sprayer
I need a wand for 101 PPG olympic deck sprayer
most hardware or home centers sell universal replacements
Jul 02, 2017 | Garden
I need a service manual for an Olympic 254 chainsaw.
I have attached a link to a website called chainsawr. They boast of having the largest inventory of used chainsaw parts in the world.
More importantly they have an Oleo-Mac Olympic Chainsaw Workshop downloadable pdf Service and Repair Manual.
It will cost you a mere $ 5.00 for the download
http://store.chainsawr.com/collections/olympic
I hope this helps.
Nov 06, 2014 | Garden
HOW TO STAIN TREATED LUMBER ?
To stain decks or other projects made of treated lumber, it has to be at least one year old, to allow the moisture from the treatment process to dry out. It the deck is already older than one year, then wash it with a deck cleaner, rinsing well. Give it a couple days to dry out entirely, then you are free to stain according to your stain manufactures instructions.
Aug 01, 2014 | Gilmour 2 Gallon Wood Deck Stain Pump...
Just bought the Ace 2 gal poly deck sprayer but it will not spray just puts out a stream of stain..is there something extra I should have purchased to get this to spray ??
I had the same problem. The deck sprayers are meant for thin liquids, not the heavy stains. Some stains have a thin consistency, others are thick. You can go back and buy a thinner agent for your particular stain, but , in my experience doing that, it thinned it too much, the color was off and didnt cover right. I ended up using a roller and brush to do the job right.
Sep 19, 2011 | Ace Hardware Ace 2Gal Home and Garden Poly...
The top sprayer is not spraying any water and the middle sprayer has water except it does not have enough pressure of water to spin around the sprayers. What do I need to do to fix the problem
All sprayed water comes from the pump located at the lower deck. Remove all parts from the lower spray assembly (note position and orientation of each part) down to the deck. There should be a large filter screen at the bottom that commonly becomes plugged with food and hard water deposits. Soak the screen in a mixture of hot water, white vinegar, and dish detergent for an hour or two until the deposits come free. Check around the pump area and the deck openings for any debris plugging. Reassemble in reverse order, but check all three spray arms for spray hole plugging or split seams. Hope this helps!
Jun 11, 2010 | Dishwashers
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Where do i find parts for a RoundupĀ® Branded Tank Sprayer System.
Hi.
roundup branded tank parts/repair kits can be found here Amazon com roundup sprayer parts Just click on the link and choose one (which fits our budget, model etc...)
I hope this was helpful.
enjoy
Apr 18, 2009 | Garden
PPG Olympic Premium Deck Care Sprayer Logo
758 people viewed this question
Top PPG Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a PPG Garden Expert? Answer questions, earn points and help others
