Question about Kenmore Dryers
How do i open a kenmore dryer model 110.76652500
I have a kenmore gas dryer does not rotate believe the delt is the proublem. model #87870100
note Kenmore/Whirlpool same belt configuration:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
how to open dryer:
http://www.applianceaid.com/wpdryer_how-to.html
Mar 19, 2011 | Kenmore Dryers
We need parts for a dryer but do not know the model
The model number on Kenmore Dryers is located on a nameplate on the door facing as you open the dryer door. The number should be prefixed by "110". Hope this helps you.
Feb 15, 2010 | Kenmore Dryers
Where is the heating element in the kenmore dryer
It depends upon the model number.
Most Kenmore dryer elements are accessible after you remove the rear panel of the dryer.
If your dryer does not have a removable rear panel you must open the top lid and remove the front panel.
Jan 16, 2010 | Kenmore Dryers
Have a Kenmore model # 97591240. Dryer is not
Hi, if the igniter is not glowing then the problem will be with the thermal fuse. I'm going to assume this is a whirlpool made Kenmore since you did not provide the full model number so please remember this when rating. If you remove the back from the dryer and look down and to the left you will see the thermal fuse it looks like this:
http://www.applianceblog.com/mainforums/attachments/whirlpool-kitchenaid/415d1159395986-dryer-timer-wiring-thermalfuse.jpg
Pull the wires off and test it with your ohms meter. If as I suspect it reads open replace it. If you have any other questions please feel free to comment. Mike
Jan 02, 2010 | Kenmore Dryers
Dryer door
I would try to run the dryer again. If that doesn't work, it's time to call the repairman.
Aug 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryer runs no heat
the kenmore is manufactured by Whirlpool. there are thermal overloads in the blower housing and one in back where the elements are. if these overloads open, 1) motor won't run 2) element won't turn on. check for an obvious open element.
Sep 13, 2007 | Kenmore 63942 Dryer
Dryers Logo
37 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
