Question about Plantronics Audio 510 USB Headset
Audio 510 usb headset driver - Plantronics Audio 510 USB Headset
Minchai USB-510 headphone drive
I have a Minchai USB-510 headphone but can't work it device. What can i do?
Oct 22, 2012 | Plantronics Audio 510 USB Headset
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Can't hear my pc to head set..can u help
Hearing a Plantronics Voyager 510 headset through a computer:
To use a Plantronics Voyager 510 headset through your computer, you either need a USB Bluetooth adapter or you must have Bluetooth built in to your computer. Once the Voyager 510 headset is "connected" to your pc (by one of the mentioned ways), you may need to go into the control panel on the computer or the specific software program being used to set the Plantronics Voyager 510 headset as the "default device". Keep in mind that the headset has to be powered on and to also have to activate the headset to connect to the Bluetooth adapter or computer.
Good luck from Headsets Direct - 800-914-7996.
Aug 20, 2011 | Plantronics 510 Voyager Headset - PLN-510...
I have lost the plantronics driver to SP500. Help!!
Hello there,
Drivers are always online no worries here is a link to Download the new Drivers for this unit
http://www.starasia.com/SP500driverdownload.asp
thank you don't forget to Rate
Jan 25, 2011 | Plantronics Audio 510 USB Headset
Do I need a driver for plantronics USB DSP v4 audio interface
Yes you would need a driver for your Platronics headset if you intend to connect it to your PC
Could you please describe the model of your plantronic headset so that i can get the required drivers for you.
Thanks.
May 21, 2009 | Plantronics DSP-400 Headset
Xbox 360 Controller and USB Headset Conflict
Go to control panel, sound and audio, hardware, USB devices, and disable it. The computer thinks the XBox controller is an audio device and is giving it priority.
Aug 26, 2017 | Logitech 250 Headset
Noise reproduction problems
I called into Plantronics  Support Phone Number: 1-800-544-4660  with similar issue;  Noise at other end.  Tech (Oscar) told me if I had evidence of purchase date, the one year warranty valid and to send in unit with copy of original receipt.  A replacement will be sent back within 3-5 days of receiving.  He told me to just mail it in an envelope.  No box is necessary.  Hope you call in and get same response.
Aug 11, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics Audio 510 USB Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
