Sanyo FVD5833 58" LCD TV has backlighting flashing off and on but image is OK. Pulsing at about 3-4 times per second.
zjut
  • 106 Answers
SOURCE: lcd tv backlight prob
You need to replace the inverter board if you can find the spare part. Otherwise you need to replace the whole lcd panel.
Posted on Jan 01, 2008
dsacco86
  • 1077 Answers
SOURCE: Sharp LC-26D43U Power light flashes and unit won't turn on?
It's a power supply related problem. When it turns itself off, this it called protection mode. The TV automatically turns off to protect other parts form being damaged.
The most common problem is the Power Supply Unit or the Backlight Inverter Board.
You may have to take the TV to a repair shop to find out which one is bad. Paying a repair shop to replace the board for you maybe more than the TV is worth. If you let them diagnose it and you replace the bad circuit board yourself, it would be cheaper.
Here's a place I use to get parts for TVs:
http://www.shopjimmy.com/catalogsearch/result/index/?q=LC-26D43U&p=1
The problem is the repair shop may charge you double or three times of what the part costs at the web site link above. Then, plus labor. I just want to save you money. :)
Posted on Jun 03, 2009
  • 453 Answers
SOURCE: Sony Bravia 46S2010 LCD backlight ok , no video
yes it is
Posted on Jun 18, 2009
SOURCE: samsung lcd tv no picture just sound
While this is not a permanent solution, we've fond it helps... We have a Samsung LCD that does not turn on when there is too much humidity in the room. This only happens in the summer when it gets really humid. We moved our dehumidifier next to it, let it run for around 15 minutes and the TV turned on again, no problem. Lately, it's been raining alot so it's very humid. We've gotten into the habit of leaving our dehumidifier on through the night on low and we've had not issues turning on the tv since then. This is a hastle but it's either that or buying a new tv.
Posted on Jul 25, 2009
  • 8457 Answers
SOURCE: Sanyo lcd tv blinking
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Apr 02, 2010
How do I fix my TV that will give an image after powering on, and then make it go so dark you can't see it?
This is what happens when the backlighting circuit fails. It can either be the lamp or the inverter board. This is one reason the newer TVs/Monitors are using LED backlighting. They last longer. Typical LCD backlighting can fail in as little as three years if they are left on full time.
Apr 14, 2015 | Sanyo DP42848 LCD TV
Tv started screeching then screen went black volume and channels ok
Sounds like this:
http://www.coppelltvrepair.com/p/428/sanyo-dp42848-p42848-00-backlight-inverters-replacement-for-dark-screen-no-image-problem
Of course your TV model may be different and the inverters may be different...but the description points to the same problem.
Aug 15, 2013 | Sanyo 42 in. LCD TV
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
Apr 20, 2011 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
37' lcd sanyo. sound no picture. no backlight. when turned on screen will flash on for a second, power indicator light stays on . Hear electric static sound when screen flashes
Check the lamps connectors on the backlight inverter board make sure they are not loose. You may be ahving failing inverter board itself.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 22, 2010 | Sanyo DP37647 37 in. LCD TV
What is subfield ? panasonic says subfiels what is subfield ?
Does this help
A standard video signal is actually a series of still images, flashed on screen so quickly that we believe we are watching a moving image. The typical frame rate used in North America is 60 frames per second (60Hz) meaning that a TV would display 60 individual still images every second. Sub-field drive is the method used to flash the individual image elements (dots) on a plasma panel. For each frame displayed on the TV the Sub-field drive flashes the dots 8 times or more, meaning that the dots are flashing 480 times per second (480Hz) or more. (Example: 60 frames per second x 8 sub-fields = 480 flashes per second). subfielddrive_en.jpg
Jul 10, 2009 | Panasonic Televison & Video
Tv wont turn on
I have a pile of these in my shop. Unfortunately and usually, a backlight lamp is bad, and the inverter board is damaged when it goes out. The backlight lamps are sealed inside the panel, so the usual method of repair is to replace the panel.
If you turn the lights off in the room, then turn the tv on, you will probably see a momentary flash of light from the backlight trying to start up. The lamps can be replaced, but the option is not really cost effective given the amount of time it takes to replace them/very delicate nature of the lamps/availability of the lamps/cost of the lamps. Replacement panels might be available, but you'd have to use a TV shop for reference or call Sanyo directly.
These units also have a history of power supply heat damage, so if you don't see the momentary flash, it could be the power supply. But the momentary flash is the dead giveaway.
I hope this helps you...
Dec 30, 2008 | Sanyo DP32746 32 in. LCD Television
Sanyo DP32746 screen black no sound screen flashes when turned on
Hello, I just posted this to another user's question, and you might find it useful, too.
Dec 10, 2008 | Sanyo DP32746 32 in. LCD Television
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
