Question about Omni Print OM200 Matrix Printer
Ac adapter canon k30263 - Omni Print OM200 Matrix Printer
My canon mp830 do not turn on what maybe the problem can u help please
Plug in another device like a lamp in the power socket to ensure you do have power available on that receptacle.
Make sure the power cord is connected securely.
If the printer does not power on, maybe you need a new power adapter.
Here is one that is available:
http://www.ebay.com/itm/Canon-Pixma-MP830-AC-Adapter-Power-Supply-Adapter-K30263-QK1-2228-/301972155607?hash=item464ef16cd7
Apr 28, 2016 | Canon Office Equipment & Supplies
REPER AC ADAPTER K30263
K30263 Adapter..... is REPER "REPAIR"
CANON K30263 AC ADAPTER 32VDC 0.9A 24V Used POWER SUPPLY PIXMA M
$59.99
Condition : Used
Content : One Adapter only Manufacturer: CANON
Model Number: K30263
Part Number: QK1-2228-000-DB01-01
> Input Voltage: 120-240V~ 0.9A 50/60Hz
Output:
32V === 0.9A
24V === 0.5A
24V === 0.03A
Output Connector Type : 2 rectangle White Flat
1 x 2Pin, 1 x 7Pin [ • • ] [ • • • • • • • ]
Dimension: 17 x 10.5 x 7 cm approx.
Weight: 310 grams approx.
Compatible with: Canon Pixma MP830 Printer K1027 K10270 QC1-9029-DB01-01
http://azsurplus.com/index.php?main_page=product_info&cPath=1_24&products_id=1211&language=en
Feb 26, 2015 | Office Equipment & Supplies
Need to find source to buy canon ip4300 ac power adapter
press canon smarthead button .reports , then print user config page
Feb 19, 2013 | Canon PIXMA Office Equipment & Supplies
I want to find the part # for canon 3000f AC adapter.
http://cgi.ebay.com/AC-Power-Adapter-Canon-CanoScan-3200F-Scanner-12V-/300416673485?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item45f23aa6cd
this is for the 3200F ..but in the same range cause I know for sure that on your model is a 12 V adapter ...take a look and if the plug is the same ...you can take it without care cause it will work ...
Apr 26, 2010 | Canon CanoScan 3000F Flatbed Scanner
Need to know the polarity of the dc3.5v input on sx100is please.
Hi - Check the following web site for an equivalent charger:
http://www.batterygenie.com/ac-adapters-5/digital-camera-camcorder-39/canon-adapters-41/ack-800-ca-ps800-equivalent-ac-adapter-147.html
If you enlarge the picture you can just make out it's center positive:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 08, 2008 | Canon Cameras
Canon mp830 printer won't turn on
Please stop! First you must try the simple solution described elsewhere.
Unplug unit. allow it to sit for 20 minutes. then plug it in. hit 'power' button. it worked for me (and others)
Jun 07, 2008 | Office Equipment & Supplies
Does Anyone know how to test Canon i860 AC Adapter??
Yes I know. put the adapter into the plug and switch on, and put the another side in a glass which contains water, then you can observe water avaporate or not. If water avaporate it is working otherwise it is not working. Just try and send me reply pnbab@hotmail.com
Nov 04, 2006 | Canon i860 InkJet Photo Printer
Omni Print OM200 Matrix Printer Logo
Top Omni Print Office Equipment & Supplies Experts
k24674
Are you an Omni Print Office Equipment and Supply Expert? Answer questions, earn points and help others
