Question about Respironics Health & Beauty
My respironics motor does not operate on connectiing to power point.However it operates when the external battery pack is connected.
toto
  • 425 Answers
SOURCE: Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Posted on Sep 15, 2005
  • 174 Answers
SOURCE: Garmin 660 wont operate on power lead
Are you using the Garmin AC adapter or the Garmin car adapter? Using the wrong cable and the Garmin will think that you are trying to connect to a computer. Not all USB cable are alike.
When connected to your computer it thinks that you want to upload or donwload information.
Posted on Jan 29, 2008
SOURCE: Power cord failure to make a good connection
I had the same problem and it was the USB and Power connector board which I purchased from PartStore.com
ORDER SUMMARY
HP DV6149US USB & POWER CONNECTOR BOARD
$20.95 x 1 unit
$20.95
Subtotal: $20.95
Shipping & Handling: $7.95
Tax: $1.95
Grand Total: $30.85
hope this helps!h
Posted on May 02, 2009
  • 10 Answers
SOURCE: Hook up for one battery operation for minn kota trolling motor
I am not sure which trolling motor you have but click the link and scroll down to select your trolling motor the battery hookup is the last page
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
Gort007
  • 1187 Answers
SOURCE: Laptop will not operate or charge the battery from
1. Power OFF laptop
2. Remove battery
3. Use power pack and turn ON laptop (without battery)
4. The laptop will work.
5. After Windows has settled down, insert battery (with laptop on and Windows running).
6. Allow the power pack to catch up a couple of hours.
7. It will work now...
Posted on Sep 25, 2009
How to repair ridgid r82007 battery?
check the charger first for correct operation
power tool batteries are prone to memory block so if you do not completely drain a battery ,it will recharge only to the last voltage point recharged
to ways to fix
take it to a battery shop that may be able to force charge the pack
have the batteries in the pack replaced with better quality batteries
buy a new battery pack from an authorized dealer
Sep 06, 2015 | Ridgid Drills
Please help! I have a gateway NE51006u Intel celeron quad core processor N2920 windows 8 laptop. Recently it has been making clicking and notifying me that there is no bootable device. I have tried all...
Solution 1: Instructions for Performing the Power Discharge Procedure (ATX Reset)
Information:
Your computer has no power at all or cannot boot properly. In some situations this can be caused by an external device or an electrical problem. This can usually be solved by removing all external devices and resetting the power supply.
Instructions for laptops:
1. Disconnect all external devices you have.
2. Unplug the power adapter from the laptop.
3. Remove the battery pack from the laptop.
4. Press the power button and hold it for at least 15 seconds.
5. Reconnect the power adapter.
Do not yet reconnect the external devices, they should stay disconnected. Do not yet reseat the battery pack.
6. Switch your laptop on and test if it boots normally and watch if the power LED lights up.
7. If the power LED still does not lights up, continue with the next steps.
8. Disconnect the power adapter from the laptop.
9. Press the power button and hold it for at least 15 seconds.
10. Reseat the battery pack. Do not reconnect the power adapter.
11. Switch your laptop on and test if it boots normally.
Solution 2: Unplug and reconnect System Hard Drive
1. Unplug the power adapter from the laptop.
2. Remove the battery pack from the laptop.
3. Unplug and reconnect System Hard Drive. This is normally accessible by removing a panel at the bottom of the laptop or removing the back enclosure (see User Manual).
4. Reseat the battery.
5. Switch your notebook on and test if it boots normally
Jan 03, 2015 | Computers & Internet
I have a code E-35
Just so you know there is a recall on this and may end up with a new one... read below
Respironics, the manufacturer of the Respironics REMstar Heated Humidifier, has received complaints of failures of the AC inlet connector on the REMstar Heated Humidifiers manufactured between December 2001 and April 2003. A small number of these failures have resulted in thermal damage to the humidifier enclosure, and there is a remote possibility that a thermal failure could result in the ignition of materials external to the device. For this reason, Respironics is asking that you remove the humidifier from its power source. You may continue using your CPAP device.
Respironics has decided to take voluntary action to mitigate the risk of failure. This action includes only the model 1005792, U1005792, R1005792, SC1005792, AC1005792, and 1007861.
This voluntary action is classified as a medical device recall, and is being conducted with the knowledge of the United States Food and Drug Administration (FDA).
WHAT TO DO:
Call Stericycle, Inc at 877-574-5038 or 317-275-7667.
Jul 02, 2014 | Respironics Remstar heater humidifier -...
Pc wont recognize my hp simplesave 2TB external hard drive
No PC stated
No OS stated. (operating system) nor if PC is internet connected.
no Simplesafe model stated, is it the 3.5" HDD? version
id yes it needs power pack to use it. HDD uses huge currents to start up. and spin.
USB ports?
if the drive fails on all PCs, the drive is bad. (or was erased by grimlin's in the night)
plug in the power pack 12vdc is correct.
do not mix it up with other packs or boom.
then listen to the hdd case with you ear, here it spin up?
if not the pack is dead, or the hdd is dead.
here is the power pack for it sold in stores
see that model number there you forgot, to mention, MD2....~~~~
12V Mains AC-DC Adapter for HP Simplesave 2TB MD2000HB External Hard Drive HS....
the drives can fail and be good.
for many reasons.
  1. bad usb port
  2. usb port driver missing.
  3. OS virus corruptiong
  4. drive fails to spin means no 12vdc power. (bad power pack)
  5. using a laptop and expecting the weak USB ports to start HDD motor, will never happen, on large 3.5" HDD. some cant even start a 2.5"
http://www.pcdied.com/external-hdd.html
Aug 24, 2017 | HP SimpleSave 2 TB USB 2.0 Desktop...
I have a euro cyber digitial camera.i purchased in sinapore about 3 yrs ago.and the the screen is,nt working
I'm sorry that the screen of the Camera is not working. Please follow the below steps and check the operation:
  • Please fully charge the battery and check the operation.
  • Perform a power resetting by removing the battery(battery pack in some models) and then press and hold the power button for more than 15 seconds. Then reinsert the battery and check the operation.
  • Press the Reset Button if one is available using a sharp pointed object.
If the issue persists, please get back to me with the exact model # of the Camera so that I can provide more specific instructions.
Thanks for understanding. Please let me know if you require any further assistance.
Sep 10, 2011 | Cameras
I am looking at the same problem/solution
Ok, Heres the deal. A gel cell battery is 7.2 Ampere hrs, so to get 14,4 Ampere hours you would need two batteries connected in parallel. A F&P machine such as mine consumes around 60 Watts of power. Using Ohms law we get W= IxE or Watts = volts X amps[or amperes = watts / volts] so that a 60 Watt machine has a current draw of 60/110< =0.55A so that a 14.4 A/hr battery will run this machine for around 20hrs (allowing a residual charge of 25%)
Jun 23, 2009 | Duracell Standby Power Plug 400 Watt...
Model 950 respironics oximeter stopped working
Here is the manual for your device http://global.respironics.com/ServiceManuals/Service950Oximeter.pdf
The troubleshooting guide does recomend making sure you have the batteries postitioned correctly. Also if the battery did leak into the unit it might have ruined it, I would really suggest getting a new unit to ensure acuracy it is sensative equipment and it sounds like the unit may have been comprimised.
Jan 30, 2009 | Respironics Finger Pulse Oximeter 1 year...
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Metz 45CT-4 power output
Have it serviced, or sell it. The culprit of this malfunction is either a faulty quench capacitor, of high capacitance and voltage, but small physical size, or a thyristor. Both are made of "unobtainium", can only be cannibalized from organ donors.
Apr 13, 2008 | Metz 45 CL-1 Flash
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Health & Beauty Logo
47 people viewed this question
Top Respironics Health & Beauty Experts
David Payne
David Payne
 Bob S
Bob S
Level 1 Expert
Are you a Respironics Health and Beauty Expert? Answer questions, earn points and help others
