Question about Sewing Machines
Aquaflow water timer settings - Sewing Machines
HOW TO SET COLORS IN FABRIC
You can soak the fabric in vinegar and salt water... Gently swirl the fabric around in the solution, change the water with fresh water, and if the colour still comes out, drain and repeat as necessary until the colour stops coming out.
Apr 21, 2017 | Sewing Machines
Brother's Sewing machine making a loud knock and not a clean stitch. Someone mentioned could be the timer. appreciate any help you can give me. thank you
there is not timer but the timing might be off between the needle and the bobbin a repair shop can test and fix that
Mar 01, 2017 | Sewing Machines
Oil icon will not go off
Probably a timer set by the manufacturer.
Internal and will be switched off when you go in for a Service or Maintenance.
Mar 24, 2015 | Sewing Machines
Can I undo Timer reset?
Sorry no, there is no Undo. However, an Authorized Viking Dealer Service Tech and check the timer on the Service configuration of the machine. It is not affected by the Timer Reset.
Jun 14, 2014 | Husqvarna Designer I
Unitrol heater control
If the heater was manufactured in 1967, it could be time to replace it.
Nov 07, 2013 | Sewing Machines
We installed sensor detectors in the light switch that controlled the florescent lighting over my sewing/work area. The timer was not set properly and the outlet overheated and caused my machine to...
hi it sounds like something has shorted in the machine itself, this would defiantly be a janome repair mans job, have you checked the fuses? i think this has an internal fuse somewhere on the underside if its the same model i am thinking of, check them first, but if the socket fuse is ok, and the internal fuse is ok, then i am afraid it will be a call out hope this helps...
Jun 05, 2010 | Janome Sewing Machines
Internal timer on Husqvarna Diamond
Sorry, this is information only provided to certified husqvarna viking service technicians. You can see the sewing hours in the user interface by going to the 'tools/set" menu.
Nov 05, 2009 | Husqvarna Designer I
Rolled hem on chiffon
Turn under the edge just about 1/4" and do a rolled edge then you can go back and trim off any of the folded under fabric that may show. Also, this keeps the hem from pulling away so easily. You may also try putting some water soluble stabilizer under the fabric before you serge.
Jul 03, 2008 | Baby Lock Eclipse Serger
Needle hitting bobbin plate
Is the needle inserted correctly with the flat side at the rear and fully up into the holder ?
If yes, take off the needleplate, remove bobbin case and slowly rotate the handwheel towards you watching the relationship between needle, and the "hook" of the moving "race".
Set on wide zig zag........when the needle is fractionally past it's lowest point, and starting to rise, the hook should be level with the left side of the needle when on the right hand stitch of the zig...the eye of the needle will be below the hook, and ready for thread to be picked up for the stitch to form.
Any other result will mean your timing needs adjusting.
Feb 09, 2008 | Singer 7422
Sewing Machines Logo
18 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
