Question about Sewing Machines
How to fit the bobbin on a Joy's PF 2000 sewing machine?
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: machine does not sew- it does not catch the thread from bobbin
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not,open the bottom cover with a flat screwdriver, loosen the two 2 mm hex screws, push out and disengage the gears. Adj the hook position by turning left or right so that it is right above the eye of the needle when the needle is on its way up. Tighten the hexes. I also give my machine a good old job with a high grade geese on the gears and light old drop on all moving parts before I close the cover.
Have fun.
Posted on Jan 01, 2010
  • 192 Answers
SOURCE: Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Posted on Feb 16, 2010
  • 1788 Answers
SOURCE: Sewing machine works fine as
Go to singerco.com and download a manual for free, you are not threading it right
Posted on Aug 30, 2010
SOURCE: Necchi 215A Sewing machine Could anyone help I
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Posted on Sep 27, 2010
Testimonial: "Thanks for the answer it did not work for me though"
What #holes on 158.1786181 solid state Kenmore sew machine bobbin
Do you mean the lower bobbin spool? It should not matter too much so long as it fits. Try it on a scrap of material and see how it goes.
Mar 02, 2015 | Kenmore Sewing Machines
Rattle in the bobbin area.
make sure the bobbin is not warped or damaged
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
I need spare bobbins for es 2000
All standard bobbin reels fit in this machine
Apr 05, 2010 | Brother ES2000 Computerized Sewing Machine
I have singer sewing machine. The black casing the bobbin fits in is supposed to move when sewing, I know, but this seems to move excessively and does not fit in tight enough so that when sewing, it slips...
The black bobbin case that the bobbin sites in is not supposed to move at all, on the right hand side of the bobbin case you will see two screws, if you slacken them off you can push the guide bar closer to the bobbin case leaving enough thread to pass through the gap.
May 12, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
123 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
