My HPvs19e monitor doesnt turn on anymore. The cables and connections are good. When I unplug the power cord for a while,
then try it again, it briefly turns on (blue light) then turns off after a second or two. After that, it won't do anything. (Maybe the cord doesn't have anything to do with it - it was just the waiting part that allowed it to start briefly.) I was reading some griefs and it seems like there are some capacitors which need to be checked? If so, what kind should I get and how much are they?
Comments:
Apr 01, 2009
- My monitor was purchased about 18 mos ago. It worked perfect the day before this happened. It worked once again for a few hours the next day after this incident (don't know why) but now looks like it is permanently disabled. I've fixed many things around the house by taking them apart. I wouldn't normally try any circuit board work, but it seems like the culprits are already identified. If necessary, I have sources at work who do this stuff every day. I'm waiting for HP to respond back to my issue. Unless they offer me a reasonable trade or something, I plan to try to fix this myself. Thanks.
mhellie1, Sounds like a typical power supply problem. One thing you and many hundreds of others fail to state is the AGE of their monitor, or calculate the number of hours (+ or - 20%) the unit has on it! It does help! Also, you didn' say if it was working PERFECTLY the day before, or that it failed when in-use. YES, These lcd/fpd monitors (all brands) are notorious for doing exactly what you have described. Here are some options that you as a consumer have. First will be awarranty claim with the manufacturer. If not, then ask if they have a monitor swapout program. You send them your's+$60-$90, and they send you a Refurbished same model, with new CCF tubes, INVERTER+Switch-Mode-Power-Supply installed. Or you can check your local TV/Monitor repair shop to see if they know forwards and backwards all about SMPS/INVERTER supplys and Cold-Cathode-Fluorescent Tube replacement. LCD monitors require BACKLIGHTING so you can see what is on the lcd panel. (screen) The technology is similar to the new style screw-in light bulbs. Compact-Fluorescents. Only your tubes are thinner and straight and hung horizontally in front of a mirror on the other side of the lcd/fpd you look at. Get back back to me if you want to try to repair this unit yourself. (not recommended for novices) Yes I have replaced capacitors and lucked out on a couple of them. I'm louie12fix on fixya or lmistyrel @aol.com BYE for now.
my monitor has squiggly vertical lines. Turned off this a.m. Turned back on this evening. Don't look...
(More)
my monitor has squiggly vertical lines. Turned off this a.m. Turned back on this evening. Don't look good! Is is time for a new one? Also, when i boot up it is telling me to insert boot disk! I turn it off and turn it back on and it will load. What is going on?
hi the lcd screen sometimes goes crazy with lines and odd colors and all that looks like a bad...
(More)
hi the lcd screen sometimes goes crazy with lines and odd colors and all that looks like a bad connection but ll the wires are hooked up fine and if u lightly smack the front of the screen it goes back to normal is there anyway to fix this without buying a need monitor. thank you
my monitor did the same thin, just went blank, after turning it off and reattaching everything it...
(More)
my monitor did the same thin, just went blank, after turning it off and reattaching everything it worked for a couple of hours the quit - permantly - i found a site http://boredprojects.blogspot.com/2008/06/hp-vs19d-fix.html went to radioshack and got 3 1000uf 35v caps, and replaced the ones recommended ($1.59 each) only lloked like 2 had shorted, but replaced all 3 anyway
Today I recieved a monitor from a friend. It is a HP vs19e, and he said it was broken. He had...
(More)
Today I recieved a monitor from a friend. It is a HP vs19e, and he said it was broken. He had recently bought a new monitor, so he figured that I would like to fix it for myself.
Anyways, when I tested the monitor, it blinked from black to grey every few seconds when the Video cord was plugged in. It never shows the Bios or the usual " No signal"
My problem is not that of power like many others that have used this monitor.
I recently connected a new monitor to my pc. For some reason, even after the computer is off the...
(More)
I recently connected a new monitor to my pc. For some reason, even after the computer is off the monitor stays on. There are no settings that I could find related to this issue, only options pertaining to monitor power when computer is on. Ideas?
