Question about Star Micronics TSP800 Thermal Printer
I have a star tsp800II Rx Printer. I am having problems setting the device so that it stops at the Black Mark on the bottom. even printing a single RX it prints to the middle of the next page. It is almost Not recognizing the Black Mark Thank
eagle338
  • 4889 Answers
SOURCE: printing problem with Star Sp200
Seems like a problem with the printer head...It is usual for matrix printers and it happens due to wear and tear..You will have to get the printing head to get replaced..
Posted on Oct 27, 2007
  • 9 Answers
SOURCE: Star SP 2000 Printer
Make sure the dip switches are set identical on each printer. Use your old printer as the example They are located at the bottom of the printer near where the interface cable plugs into the printer.
Posted on Feb 23, 2009
  • 9 Answers
SOURCE: Star SP200 printing issues?
The print head has gone out on your printer. The printhead will have to be replaced
anantakumarj
  • 330 Answers
SOURCE: My Star sp200 printer dosent print with POS s/w
first unistall the printer driver and reinstall it ..........
next is change cable of the printer to new .........
if its giving same problems means go for a service center.............
Posted on Oct 07, 2009
  • 9 Answers
SOURCE: how do i do a test print on a star sp300 printer
hold down the feed button while turning the printer on.
Posted on Apr 15, 2010
How can I stop printer prining both sides (even if only a single page
Go to the driver in Devices and printers. in printing preferences locate 2 sided printing and change it to single sided. then apply and ok.
Remember the pc settings override the printers setting. Actually did this with a customer this very morning and it worked
Jan 26, 2016 | Office Equipment & Supplies
Oct 07, 2009 | Star Micronics SP200 Matrix Printer
MONARCH 9416 300DPI PRINTER
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
Jul 24, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Yellow runs out after only a few hundred prints and didn't used to
Not sure why you're going through the yellow toner so quickly. You might try pulling it out and shaking it some to re-distribute or loosen the toner inside.
Yes you can override the cartridge out of toner print halted problem. This is located in your User's manual and is stated as:
Replace Supplies feature
The printer has three options for low or exhausted supplies status:
STOP AT OUT (the default setting): The printer continues printing while a print cartridge is low.
When the cartridge is out, the printer cannot print.
STOP AT LOW: The printer pauses until you replace the low cartridge.
OVERRIDE AT OUT: The printer continues printing even after some supplies have run out.
To set the Replace Supplies feature
1.
Press Menu.
2. Press (down arrow) to highlight CONFIGURE DEVICE, and then press (check mark button).
3. Press (down arrow) to highlight SYSTEM SETUP, and then press (check mark button).
4. Press (down arrow) to highlight REPLACE SUPPLIES, and then press (check mark button).
5. Press (down arrow) or (up arrow) to select the appropriate setting, and then press (check mark button) to set the selection.
● If you select OVERRIDE AT OUT and then press (check mark button), a warning message appears. To accept the override, select YES, USE OVERRIDE and press (check mark button), and then set the page limit for the override and press (check mark button).
6. Press Menu to return to the Ready state.
Apr 15, 2009 | HP Color LaserJet 3500 Printer
Epson RX 595: Yellow streaks in black
In the printer settings, there is a button to switch to Advanced.
So, right click on the printer, select properties, click Advanced, then Printing Defaults, then there is your switch to Advanced button. That will reveal the tick box that says only use black.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Canon PIXMA MX310 All-In-One - faxes storing instead of printing
When the machine is in one of the following situations, the fax is automatically stored in memory.
- If ink is low or has run out while receiving a fax
- If the paper size/type setting is incorrect
- If the paper has run out while receiving a fax
- If the Output Tray is closed
- If OFF is selected for AUTO PRINT RX
- If you pressed the Stop/Reset button to cancel printing of a fax
The most likely problem is that the ink is low.
You can change the settings to still print if the ink is low by pushing the fax button and then the menu button.
Scroll over until you get to RX settings (I think it is the 6th option) and push OK.
Choose the option to Auto Print RX, and press OK.
Make sure that On is selected and even if it already is the chosen option, press OK.
When the option appears to print with no ink, select yes. This will allow the fax to print even when the ink is low.
Sep 04, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 Printer - Faxes being stored isntead of printing.
Star Micronics TSP800 Thermal Printer Logo
69 people viewed this question
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
sajidsarwar
Level 1 Expert
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
