Question about Canon PIXMA MP160 All-In-One Printer
Alarm light is flashing. cannot print
I have installed the driver and connected the printer with pc but the alarm light on the LCD is flashing..and cannot print anything
    Guru:
  • 377 Answers
Hi dear
this the error code
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
First, download the software at http://www.box.net/shared/4yblbn34kg
Secondly, to run the software your printer has to be in service mode. Do that by
- unplug cable
- press and hold "power" button
- plug cable
- press "resume" and release
- release the "power" button
At this stage, your computer will detect a new hardware
Run the software.
oke
Posted on Jun 14, 2008
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Getting error code "5C10" Printer not functioning alarm light flashes instructed to turn off and restart printer this has no effect.
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Aug 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printer flashes code 5 .black ink light flashes & error light on.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Office Equipment & Supplies
Can't get printer to connect
  • try to download drivers from the website by Clicking on the below link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=15402#DownloadDetailAct
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Lex. x 5495 won't print from pc.It worked up to a short time ago.Will print from laptop.Driver,cables. connections are good, occosionally will print a remaining document from previous attempts first thing...
check all this possible problems and solutions:
-Check the printer status lights, or the status LCD screen. If there's a flashing light, or if the status screen shows an error, then it's your first clue to a problem. Most printer manuals have a diagnosis process for alerts.
common problems are related to toner or toner cartridges. If the problem is toner-related, check to see if the toner cartridge is empty or low. The printer warning should indicate this. Swap it for a new one and the unit should work.
check to be sure that it is connected to your computer. Personal printers connect via either a parallel or USB (universal serial bus) connector to the back of the printer. Follow the cable from the back of the printer to the back of the computer to make sure the connection is good.
When a printer acts up and there is no hardware problem, the solution is often driver-related. A printer driver is a piece of software that allows a computer to "talk" to a printer. It's a kind of translator. Occasionally, if a printer has worked previously, but suddenly doesn’t work with a newly installed program, there could be driver problems. To remedy this, download a driver from the printer maker's website, remove the old driver, and install the new driver. Drivers are normally available under the "support" area of a website.
Sep 16, 2008 | Televison & Video
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Canon PIXMA  MP160 All-In-One Printer Logo
180 people viewed this question
Clive
Clive
old marine
old marine
