Question about Locks & Locksmithing
How to change the batteries on a kamasa digital safe?
Where is the battery compartment in my ce electronical digital safe?
do you have a round lock pad. This model has 2 9 volt batteries under the key pad
http://bestbatterytips.com/change-replacement-batter/safes-with-electronic-locks-replacing-the-battery/
Lots of info here
  • How to open digital safe when battery is flat and key not ... www.youtube.com/watch?v=aqC9V7SDKdQ
    • BY KHTHHONL
    • 1 MIN
    • 417K VIEWS
    2012-11-09 · How to open a digital safe when the battery is flat and the ... How to open digital safe when battery is flat and ... How Secure Are Electronic Safe ...
  • Locked out of my Digital Safe [Archive] - PPRuNe Forums www.pprune.org/archive/index.php/t-357319.html PPRuNe Forums > Misc. Forums > Computer/Internet Issues & Troubleshooting > Locked out of my Digital Safe. ... CE (Chinese made) electronic security safe ... battery ...
  • LA GARD LG Basic digital electronic safe lock changing ... www.youtube.com/watch?v=M07EpfSmoAU
    • BY DEANSAFE
    • 3 MIN
    • 99K VIEWS
    2009-10-13 · For instructions on this and other electronic digital safe ... How to change the combination and battery on ... Basic digital electronic safe lock changing ...
  • User Manual for Safe EA25 Installation - Tayabally www.tayabally.com/digitalsafe/mannuals/Safe EA25 Installation... You should change the code as soon as possible after opening the ... BATTERY REPLACEMENT. This safe uses ... MAINTENANCE FOR KEY AND ELECTRONIC SAFE.
  • Elektronischer Digitaler Safe Electronic Digital Safe www.produktinfo.conrad.com/...799999/...DigitalerSafe_de_en_fr_nl.pdf · PDF file Electronic Digital Safe Version 12/08 ... (CE). Any usage other than ... Replace your batteries when both the red and green light illuminate. 1.
  • Instructions for an Electronic Digital Safe ' eHow www.ehow.com > Home > Home Safety > Home Safes Instructions for an Electronic Digital Safe By Shawn McClain eHow Contributor Pin Share ... Replace the used batteries with new ones. For most safes, ...
  • Apr 24, 2016 | Locks & Locksmithing
    Tip
    How to chanmge codes on most digital safes
    To change the code on most digital safes. <br />you need to access the red button usually found inside the safe by the battery area. <br />Press the red button until you see two flashes. then enter your new code.<br /><br />PLEASE try the code BEFORE you close safe!! <br /><br />Thanks
    on Apr 29, 2011 | Safe International Digital Electronic Safe...
    I have the key I know the3 combination but still i could not open because it's in low battery
    if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
    Jan 03, 2013 | Safe International Digital Electronic Safe...
    The batteries run out and the key is inside safe ,how i can open it
    heat the safe for about an hour. This should raise the level in batteries to enable it to open. Change batteries straight away.
    Mar 07, 2011 | Safe International Digital Electronic Safe...
    I have a model 45891 Bunker Digital Safe. Battery
    how do i change combination on bunker hill 45891 safe, i have tried every way i can think of.
    Oct 05, 2009 | Check Point Network Adapter
    Bunker hill digital safe
    CHANGING CODE ON MODEL # 45891:
    On the inside of the door toward the hinge, you will see a small red button. Press this button until the yellow light on the front control panel lights up. Now you can imput the new code (1 to 8 digits) into the front control panel, followed by either the "A" or "B" key. The safe will beep twice (2 times) to confirm the code has been changed. Important: If the safe beeps 3 times, then the code has not been accepted and you must repeat the above steps.
    DO NOT LET THE BATTERIES RUN OUT BECAUSE YOU WILL NOT BE ABLE TO OPEN THE SAFE OR CHANGE BATTERIES.
    Dec 19, 2008 | Check Point Network Adapter
    Locks & Locksmithing Logo
    110 people viewed this question
    Top Locks & Locksmithing Experts
    ray gallant
    Andrew Taylor
    Andrew Taylor
    Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
