Question about Konka K2001UM TV
Stay is AV mode
My k2001um TV. Our TV only turns on and off my either plugging it in and unplugging it or turning on and off the power strip. It is always in AV mode it won't switch back and forth to TV with either the remote or the front panel switches. Anyone see this problem? I have tried changing batteries to the remote.
  • mrezac Mar 01, 2008
    The hint did not work. Sorry for he delay but the TV in in my son's dorm room at college.
    Problem Solver:
  • 11 Answers
Yeah i had the same problem, if you hold down the power button on the front of the tv for, i dont know, like 30 seconds or something, then my tv would turn off. try it.
Posted on Jan 16, 2008
  • rekha shrestha Sep 30, 2015
    your solution is not workable !!
6ya staff
SOURCE:
I have a calypso flat panel TV every time i switch it off and turnedit back on it comeson in AV mode with out me switching it from TV to AV,then i have to always go to the menue and put it bact into TV...
If you have something plugged in the AV, try unplugging that, and then switching on off etc tests. If that works and solves the problem, then the TV is sensing whatever is in the AV input, and thinks you want to use that first.
I'm not at all sure you can change this, except by making sure the thing in the AV input is either totally turned off, or unplugging it. I hope I'm wrong about this part, and if so it'll be clearly stated in the user guide some place about how to disable this auto-selection.
I hope this helps find the cause of your problem.
Dec 17, 2013 | Televison & Video
My Polytron TV is on standby mode. I used the remote but wont turned off
When you turn that TV "off" with the remote it go's into standby mode, that is the way they made it unfortunatly
To actualy make it not have any power going to it you will have to unplug it or plug it into a power strip and use the switch on the power strip.
They use the standby mode to allow the TV to turn on quickly without making you wait.
Jul 19, 2009 | Panasonic Televison & Video
TV Zoom mode
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
May 16, 2008 | Sony KV-32FS13 TV
On timer light blinks on/off tv does not turn on jvc av-32d502
Well, it sounds like the TV is in timer standby mode and thus preventing the TV to turn on or off.
  • Very simple thing you can try to reset the TV is to unplug it from the wall and leave it unplugged for about 5 minutes or so.
  • Next, replug in the power for the TV and see if the timer mode has been cancelled out.
Regards,
Feb 16, 2008 | Televison & Video
How to unlock my Konka K2001UM TV
check the tv's manual to see if there is anything about a "Child" or "Button Lock" feature.
Jan 16, 2008 | Konka K2001UM TV
JVC AV-36950 TURNS OFF
Replace C953 1000mf / 35v in power supply....capacitor
top will appear slightly bulged or will check bad with
ESR meter...........................T.
Dec 02, 2007 | JVC AV-36950 TV
T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
13 inch Haier TV
Plug it into a power strip and turn off the power strip as well as the TV. I've been told that newer TVs are always "on" - standby mode- and someone probably has a device somewhere in the near vicinity that is turning it on. (Or your cat is watching it when you're not home.) Or you could just unplug it when you leave.
May 21, 2007 | Haier HTN13R12S 13" TV
Televison & Video Logo
196 people viewed this question
Top Konka Televison & Video Experts
Ekse
Jerry Greenberg
Jerry Greenberg
Are you a Konka Televison and Video Expert? Answer questions, earn points and help others
