Question about Amana Heating & Cooling
Amana ptac unit leaking water on the floor - Amana Heating & Cooling
oscarn
  • 109 Answers
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Posted on Sep 07, 2007
  • 49 Answers
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
Posted on Nov 18, 2007
  • 6 Answers
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Posted on Sep 09, 2008
  • 26 Answers
SOURCE: Remote Thermostat
call the amana dealer nearest to you order one
Posted on Nov 27, 2008
  • 142 Answers
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Posted on Feb 12, 2009
My Amana PTAC unit is not cooling properly I just cleaned everything on it the coils and everything is still not cooling properly
check to see if the compressor on the outdoor unit is running, if so it could possibly have a refrigerant leak or faulty 4 way valve
Apr 27, 2016 | Amana Heating & Cooling
The flow switch on the Amana ptac unit is not opening causing water to build up. How do I get it to drain into the sleve?
run a coat hanger inside the sleeve and then spray some bleach through the fins and then put the filter back on and run it
Jul 26, 2015 | Amana Heating & Cooling
My amana ptac is not heating....the code "np" is displayed....how do I correct this...we just installed the unit and know little about operation. Thanks
I don't see this error code in the manual. I do see nP as an error code for Window Switch lockout. I just had this happen to me and they had me reset the control board.
Remove case, flick master switch to OFF for 10 seconds. Press Heat/Cool same time turn switch back on HOLD until off light comes on.
You should be fixed. Just had to do this for my unit. I was playing around with the settings and turned on the window switch option by accident.
Feb 02, 2013 | Amana In Wall Install Kit For Digismart...
I have an Amana BRD18V1 or V2, bottom freezer. About every two weeks it leaks water on the floor on the right hand side and i have to defrost the bottom part to get about an inch of ice out. I trust...
I assume you mean water leaking on floor of bottom freezer? There should be a small hole in floor in back to drain defrosted water down to pan under unit. This line might be clogged with food or frozen water. Carefully pour some hot/boiling water down tube to clear. You should see it empty into pan under unit where fan evaporates it.
Jul 15, 2010 | Amana ABB1927DE Bottom Freezer...
I have a zoneline ptac unit. The water keeps
They used to use a black rubber hose to run from the front to the back of the unit on the very bottom of the unit. You may also look for a styrofoam chute . Make sure the unit is sloped to the rear slightly.
Aug 18, 2009 | General Electric Zoneline® Deluxe Series...
Too much water condensation !!! what should i do
that means it's working, It's humid out it's going to put out several pints a day possibly a gallon or 3 find somewhere for the water to go
Aug 11, 2009 | Amana PTH123B25AJ Heat Pump Air...
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
We are doing preventive maintainence on Amana
bottle of nitrogen with a blower attachment.do use water.if will stuff it
Jun 09, 2009 | Amana PTH123B35AJ Air Conditioner
Need parts for an Amana PTH123A25AA PTAC
The Amana parts line # is 1-800-227-2919, you can also obtain parts numbers and names from their website, www.amana-ptac.com.
Please rate this answer and let me know if this helps.
Dec 13, 2008 | Amana PTH123B25AJ Heat Pump Air...
GE Zoneline PTAC Leaking
Hi Julie,
Is this a newly installed unit? The problem sounds like the sleeve is improperly installed. The sleeve should slope approximately 1/4 inch downward from inside to outside. This way the water will run to the back of the pan where it will be picked up by the slinger fan, or drain to the outside. Most likely this is the cause, not the styrofoam pan. If you need further info, you can contact me at greg.mcnary(at)airdistributors.com (replace (at) with @) and I can get you detailed installation instructions.
Greg McNary
Air Distributors Company, Inc.
Distributors of GE Zoneline PTAC Units and
McQuay PTAC Units
Aug 06, 2008 | GE Zoneline AZ38H12DAD Split System Air...
Heating & Cooling Logo
528 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
