Liteon power supply
Ineed to know pinout of liteon power supply pa-1131-4a-lf connector +53 5 293 2497 +53 5 286 4747 +53 5 829 4018
gripfitter
  • 557 Answers
SOURCE: Turning on a Liteon power supply without being hooked up to compu
On the main plug there are several black wires(ground), and one green wire. Jumper any black wire to the green wire and there you go.
Posted on Dec 14, 2009
Testimonial: "Your solution worked perfectly Thank you very much Bill"
gripfitter
  • 557 Answers
SOURCE: Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Posted on Dec 20, 2009
  • 1027 Answers
SOURCE: cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Posted on Jan 31, 2010
pravinbhavsa
  • 348 Answers
SOURCE: GERICOM laptop power charger - Liteon model PA-1900-005
yes this is common rating for laptop any laptop adapter can be replaced see the output voltage and current of another adapter matching . if connector is not matching then solder the matching connector
Posted on Mar 07, 2010
SOURCE: Pinout for dell power supply with model number Ep071298
There are no wires, it's a big hot-swap plug.
Posted on Mar 14, 2012
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
Rh11@gmail.comdoes not fire up green power light on but cooling fans dont run and multi meter does not register any power through
Remove power supply from PC, connect it to AC power, then connect green wire with any black wire.
If it starts - check 12V AC, 5V AC.
If it doesn't - there are no user serviceable parts inside, just replace power supply
May 19, 2011 | Lite On LiteOn 204Watt PA-4022-6B Power...
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
Mar 03, 2010 | Computers & Internet
Dec 13, 2009 | Computers & Internet
Acer aspire computer with liteon power supply PY300B00153201AA6E
power supplies are easy to replace. usually 4 screws. open the pc. remove the screws and unplug it from the motherboard. a replacement costs 40-60 dollars. plug it into the same place(s) you unplugged the original pwr supply. replace the screws. replace the cover and thats it.
Jan 08, 2009 | Lite On LiteOn 204Watt PA-4022-6B Power...
Power connection pinout
Here is a pin connection specification for the ac power supply (dual voltage adaptor)
>socket/plug for a Compaq TFT450 LCD Monitor that she
>supplied (edited for further clarity).
>The pins of the male connector (a PS2 mouse type connector) should be connected like this:
> 1 2
> 3 I 4
> 5 ^ 6
> GND GND
> 5V I 12V
> 5V ^ 12V
>For clarification - the male will be the end of your cable, and not the socket on the monitor.
>The I is the central polarising bar of the connector, and the ^ is the notch.
Jun 16, 2008 | Compaq TFT450 14" LCD Monitor
Computers & Internet Logo
271 people viewed this question
David Payne
David Payne
