Question about Xerox Phaser 7400/N Printer
Phaser 7800 led fault - Xerox Phaser 7400/N Printer
Xerox phaser 7800 rebooting all time
Most likely cause is corrupted software which requires an alt boot which requires the Xerox laptop to reinstall.
Apr 09, 2016 | Xerox Office Equipment & Supplies
How set factory default xerox 7800
Solution : Reset the Printer to the Factory Defaults (Reset NVRAM) WARNING: Only use the tool when directed to by Xerox Service. All user and system settings will be lost.
  1. Select [Printer] on the Touch Screen.
  2. Select the [Tools] tab.
  3. Select [Setup].
  4. Select [Service Tools].
  5. Select [Reset NVRAM]. A confirmation screen will be displayed.
  6. Select [Reset NVRAM] again.
Related Knowledge Bases:
Mar 05, 2014 | Xerox Printer Division Xerox Phaser...
Engine failure
Hi Zelwe Mwanza
show me error code pls
Dec 27, 2013 | Xerox Printer Division Xerox Phaser...
Xerox Phaser 7800DX not printing one particular file; error code 389.601.00
Make sure your are using Postcript Driver & not the PCL6 driver and that the document page size and the paper page size in trays are the same.
Dec 26, 2013 | Xerox Phaser 7800/dx Workgroup Laser...
How to fix problems with electric contact of a xerox phaser 7800dn
Go to the Xerox website and read up on your model. Also see if there is a fuse blown between the power cord and the system itself. Maybe the transformer has died. and needs to be replaced. That happens a lot with devices with 'step down' transformers combined with the electric cord as opposed to transformers built into the device.
May 31, 2013 | Xerox 7800/DN - Phaser 7800dn; 12 X 18...
My Photoshop sends a print job 100 times to my Xerox 7800 instead of once for 100 prints.
I also have this issue running a xerox docucolor 550 and PS-CS6 the only soloution i have is to save the file as a pdf and send it from firey comand center if you are running a firey server command center is available from xerox website
Sep 11, 2012 | Xerox Phaser 7800GX LED Printer - Color -...
Xerox Phaser 7400/N Printer Logo
29 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
