Question about Lands Phones
How to get a dial tone on panosonic model kx-tga401c
  • 25 Answers
SOURCE: my KX-TG 8231B
Make sure the phone is pluggd into the wall properly. If so and no dial tone is detectable make sure you installed the batterys on the handsets correctly and that they are fully charged. If you have a friendly neighbor with a working phone line plug youre phone into their line and if it does not work and you followed my previous instructions seek a repair center in youre area that honors panasonic warranties. If the phone is pluggd in at the neighbors house and it works use it to call the phone company.
Posted on Mar 26, 2008
SOURCE: KX-TGA110FX
1.Press (ok)
2.Arrow down(twice) to "setting BS" then right
3. Input PIN code.Usualy 0000
4.Press "1"if you want TONE dialing or "2" for PULS
5.Press right arrow,then on/off button
Posted on Mar 12, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Posted on Feb 20, 2010
SOURCE: "Panasonic phone Model no.KX-TSC35MXW DIAL
how i can solve the restraction of calls
Posted on May 03, 2011
Panasonic kx-tg2511e two-tone dial tone
It's stutter dialtone and indicates you have voicemail. Once you clear your voicemail the stutter tone will go away. You may also have a visual indicator that you have voicemail like a light or icon on the display.
Oct 23, 2012 | Panasonic KX TG2215S Phone (KX-TG2215S)
How do i adjust the volume on my panosonic kx tga 131az cordless phone.
With Panasonic phones the volume of whatever function is active can be adjusted with the arrows button. While it is ringing use the arrow up or down to adjust ringing volume. When off hook (you can hear dial tone or you are on a call) use arrows to adjust handset volume.
Dec 08, 2010 | Panasonic KX-TG5632 Phone
I have panasonic kx-tga401c model and want to set the answering password so i can my mess when i am not home from outside?
I have panasonic kx-tga401c model and want the volume at "maximum" is soft. Does it an other way to have our volume more louder!
Oct 07, 2010 | Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
No dial tone
try pulling the batteries out for 24 hours and then putting them back in. It should reset all the software and it should sync back up.
Jul 25, 2008 | Uniden DCT646-2 Cordless Phone
Panasonic KX-FM220 fax machine does not have a dial tone
is your line provider ok.connect your line to ordinary phone to check if there is really a dial tone from the line provider.if there is a dial tone please let the analog board be cheked by a technician near you
May 01, 2008 | Panasonic KX-FM220 Plain Paper Thermal Fax
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Lands Phones Logo
26 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
