Question about Northstar Garden
Northstar pressure washer 157754F manual where can
Northstar pressure washer 157754F manual where can I get one
  • 17 Answers
SOURCE: looking for a manual for northstar pressure washer
Please use this link for more information for the manual:
http://www.northerntool.com/catalog/buyersguides/pressurewashers/
Posted on May 14, 2009
  • 174 Answers
SOURCE: northstar pressure washer randomly gives pressure
Hi:
You need to find the bypass (unloader) valve and grease it with a good waterproof grease. Sorry, I cannot find a pic for you
Posted on Sep 03, 2009
  • 3600 Answers
SOURCE: Northstar pressure washer needs new hose
Need to know what country you are located in and if you want a 15 foot hose or 25 foot or 50 foot hose. The reason is We have to know where you are going to buy it and if you have a dealer that that is local or not. it's a 2500 PSI hose so the hose has to be a minimum of 3200 PSI You can also have hoses fixed at local hydraulic shops in the U.S. in the local phone book, they can make up the hose you need if you take it to them let me know.
Posted on Mar 25, 2010
  • 68 Answers
SOURCE: Pressure washer pulsates
Could well be the main jet slightly blocked in the carburettor.
Posted on Jun 10, 2010
  • 1388 Answers
SOURCE: How do I adjust the
The following link will give you great troubleshooting for all pressurewashers. http://www.pressurewasherservice.ca/serv02.htm
There are several way to increase pressure. Primary way is to turn the pressure regulator knob in the direction to increase tension on the spring. Pressure regulator is located on the pump (or very neer) and usually has a large spring. Sometimes the spring is hidden under a twist knob. If the adjuster seems to be already turned to max then you may need to just change the pressure tip. The tip/nozzle is actually where the pressure is created by restricting the flow of water thru a very small opening. Use a new tip of the same gpm flow that is required by your machine. 18 hp machine has potential for very high pressure and high gallons per minute. Use trouble shooting guide above for more information. Good luck
Posted on Oct 01, 2010
My northstar pressure washer has no pressure
PDF]Owner's Manual - Northern Tool + Equipment
https://www.northerntool.com/.../1577544.p...
Northern Tool + EquipmentCall NorthStar Product Support 1-800-270-0810 .... -During transportation take precautions to make sure pressure washer will not tip ..... A- Low oil shutdown.
Sep 21, 2015 | Northstar Garden
Northstar pressure washer manual 157170
look on there sitefor manual.
Aug 12, 2012 | Northstar Garden
I have a northstar 2800psi 2.5gpm washer that doesn't pick up the cleaning soluion, is there an adjustment to make it **** the fluid out more?
There isn't an adjustment for pulling the cleaning solution out faster or slower. It's an automatic function, based on the size of the power washer (meaning it ****s at different rates for different sized washers). Here's a link to the manual for more information:
http://www.northerntool.com/downloads/manuals/1577543.pdf
Hope this helps!
Aug 30, 2010 | Northstar Pressure Washer 2800 PSI
I can't find my manual and no longer remember what the fuel mixture is for my workforce 163cc power washer. Can you help me? Thanks much.
Does your pressure washer engine have a place to add and check the oil level? If it does. And it looks like the picture from your question. It is a four stroke engine and the fuel doesnt need added oil.
Northstar washers are available online at Central Power Equipment.
You might find an electronic owners manual there.
Jul 17, 2010 | Northstar Pressure Washer 3000 PSI
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
Northstar pressure washer randomly gives pressure
Hi:
Sep 03, 2009 | Northstar Pressure Washer 3000 PSI
My Northstar Pressure Washer Pump does not boost water pressure
Pump will power up, but when I attempt to use the wand the motor sounds like it is running on one leg & blows circuit breaker----Ser# 1575551-1101 5160 Model #1575551E
May 11, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
222 people viewed this question
Top Northstar Garden Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Northstar Garden Expert? Answer questions, earn points and help others
