Onida 21 colour tv ic no tda9370ps/n3/a/1717 vertical an5522 audio tda7297 strg8656 i want lot no
5 Suggested Answers
SOURCE: Half part is display
replace ic
Posted on Sep 29, 2008
SOURCE: HOW CAN I ENTER INTO
It is very simple, you just need to follow the right channels and with guidelines you will get,you will be thre
Posted on Apr 08, 2011
SOURCE: DARK PICTURE ON ONIDA COLOUR TV
only for audio but after without vedio
Posted on Jun 01, 2012
gopakumarg43
  • 74251 Answers
SOURCE: Onida 21 flat tv h output transistor over hit and after ten minutes blow of
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Posted on Jan 13, 2017
7297 audio ic how to work
Here's the Datasheet on the TDA7297 IC: http://pdf1.alldatasheet.com/datasheet-pdf/view/25110/STMICROELECTRONICS/TDA7297.html
This should work for you. It also shows a recommended circuit for the part.
Jan 20, 2015 | Jl Audio Car Audio & Video
Why I have a thin line across the screen in my TV model Panasonic TC 21. After replacing the vertical IC the horizontal line across the screen reduced to few inches and not as it was earlier. vertica
First, You should to replace by original part, then you should check the voltages on power supply, and check the voltage for vertical IC based on datasheet, also check the voltages on vertical section including yoke and last you should check the ESR capacitors on vertical section.
Oct 13, 2014 | Panasonic TC-21PM10RQ 21" TV
What is theService mode code for sansui tv using IC TDA9370ps /N3/A/1839?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 30, 2014 | Sansui Televison & Video
Onida tv
Horizontal line on screen denotes the absensce of vertical sweep itself. Check the vertical output section circuit to LA7840. Check for any loose solder terminals. It will be best to measure the input voltage to that IC from the LOT secondary supply. Try by replace the IC. If these do not help you, measure the frequency from the main IC. It should be at 50Hz. If this frequency is not present, the main IC is faulty. If you wish to get some more details about the circuit, check this link. http://electronicshelponline.blogspot.com/ Pull up older posts there, either by its left side bar, or see it in Timslide option. Schematic diagrams, that show vertical IC LA7840 is given. You can compare it.
Jun 23, 2013 | Televison & Video
My sansui tv has vertical line problem ic tda9370ps/n3/a1932 and vertical ic stv9302A
It sounds that the kit is a Chinese one. Check the voltage to all terminals of vertical output IC. Check and replace it. This is a common problem to these kits.
Aug 21, 2012 | Televison & Video
My sony tv model no. kv-ha21m80 is on standby mode & its LED is blinking four times that means it has some problem in vertical section.But when I tried to check voltages of its vertical IC AN5522
Disconnect Vertical supply and so that your Horizontal system run check all voltages before connecting vertical again ...should the protection come in again when vertical connected ...replace Vertical Ic and safety resistor in line
Apr 21, 2012 | Televison & Video
How to get LOT identification number for ONIDA black 300 21 inch TV
BSC25-NO347 E1MWFL21017 , i have onida black 300 21" tv - in that LOT no is given as shown above - iam babu , computer hardware engineer, from bangalore,9986222774, - i have replaced LOT in my tv - please cal me immediately - i also need very big help from you
Mar 30, 2010 | Televison & Video
TV not tuning
This guy is raking in the change on you. The tuner is for over the air signals, now you have a 3 prong connector RED,WHT,BLACK make there connected you can find the AUX,VID-IN by scrolling throught the channels on your TV hope this helps.
Apr 22, 2009 | Televison & Video
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
Electro Med Services...
