Question about Dell (6T980-A01) CD-ROM Drive
The disc won't fit in player it's to big for the whole disc won't fit
Jammed dvd player
there is a tiny hole in the front of the disc tray, just big enough for a straightened paperclip to fit in, this will relaease the disc drawer
Oct 21, 2013 | Televison & Video
Netflix will not connect internet on vizio blueray player
see this steps and fix it. God bless you
    • 1 Reset the player if the device stops behaving normally. (Keep in mind that rotation sounds and picture issues during search are normal.) Select the "System" menu from the setup area and choose "Restore Factory Settings" or a similar option. Allow the device to restart and then try the disc again.
    • 2 Insert the disc face up in the tray. If playback fails to start or if it starts and then stops, wipe the disc with a soft cloth and try again. Throw out any heavily scratched discs that won't play.
    • 3 Change the "TV Aspect" to 16:9 in the setup area of the menu if the picture expands left and right or if the picture size is wrong and you're using an HDMI (High Definition Multimedia Interface) cable.
    • 4 Set the wireless Internet router to automatically allow new devices to connect to it if the Insignia player won't connect to the Internet. The player uses only WPS to connect. Some routers that use different automatic setup protocols won't work.
    • 5 Make sure that the connection between the player and the television uses an HDMI cable if you're watching a Blu-ray movie. Some Blu-ray discs will only play over an HDMI connection. Also, remember that some Blu-ray discs won't work with PiP (Picture-in-Picture).
Oct 15, 2012 | Vizio VBR220 Blu-Ray Player
Lost the piece that fits over the lens, won't start the dvd.
Possible that the optical head is damaged and so might need a replacement. If the piece you mentioned has come off the optical unit then the unit is damaged and will not read or pass on information to the processor to run the disc..
Jul 03, 2012 | Insignia IS-PDO40922 Portable DVD Player
Automatic cleaner won't do the whole pool? Keeps skipping big patches?
use the diagnostic system in accordign with the inst.manual or download free www. retrevo.com or www.fitness.manualsonline.com
God bless you
Jun 19, 2012 | Dirt Devil Rampage Robotic Pool Cleaner...
Dvd won't load model pet941d/37
The laser pickup overtime becomes weaker until it can no longer read the disc. Take some rubbing alcohol and a Q-Tip and gently clean the lens, allow several minutes to dry, if no change! the whole assembly needs to be replaced, not cost effective to repair.
Apr 23, 2012 | Philips PET941D/37 9 in. Portable DVD...
My vizio vbr120 will play dvd but not blu ray
This is a common problem in blu ray discs, the reason why it won't play is because they play at a faster speed and demand a higher precision to produce the high definition signal required to play the program. The only way to fix this is to replace the whole laser pickup assembly which would not be cost effective.
Apr 21, 2012 | Vizio VBR120 Player
Won't play a blue ray disc
The blueray eye is out. You will need a new blueray player. The only problem with that is the ps3 will only respond with the orginal parts it came with. ( i.e. motherboard blueray player ) So the best bet is to buy a broken blueray player and take the eye out and replace it with yours just the eye not the whole thing.
Dec 01, 2011 | Sony Playstation 3 (PS3) Console
Can i download a whole bible on my digital media player
Yes you can, provided the media player has a big enough storage capacity to fit the whole bible file.
For example, If the bible file is 12Gb in size the the media player storage capacite needs to greater than 12Gb capacity.
Jun 26, 2010 | Audio Players & Recorders
LG HDD/DVD Recorder RH177
Hi. I have this machine and it will only fast transfer if the original hdd recording has NOT been edited (i.e part deleted/divided/combined). This is also in the manual p51/52.
Hope this helps.
Adam.
Feb 06, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dell (6T980-A01) CD-ROM Drive Logo
mukhtar21 shaikh
mukhtar21 shaikh
