Question about Sanyo Televison & Video
I have a Sanyo LCD-24XR10F TV and have purchased a "ONE FOR ALL" URC-7110 remote controller to replace the Sanyo remote that no longer gets a response from the TV. I have tried all the Sanyo codes listed in the booklet supplied with the One For All remote and tried the Search Method over and over but get no response from the TV. Is their a code for this TV that will get the remote to work? Barry
5 Suggested Answers
Sparky-UK
  • 129 Answers
SOURCE: need tv code list for urc-4605
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4605
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(For low price replacement remotes visit www.sparky-uk.com)
Posted on Feb 25, 2008
IrishDruid
  • 2712 Answers
SOURCE: remote control codes list for a sagem settop digi box
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • 29 Answers
SOURCE: programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
Posted on Sep 25, 2008
SOURCE: URC 7510 (no barcode for LG tv?)
i phoned sky with problem finding the number for my LG and they said it was only a monitor and not a tv and therefore there was no code for it....any help to you at all?
Posted on Oct 28, 2008
I NEED SANYO TV CODES FOR A URC-4021B00 ONEFORALL REMOTE
Jadan, CODES FOR SANYO TV try 0154, 0240 0047, 0104 Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What is the code for Sanyo TV remote control One for All URC 3220
http://www.rockabilly.net/files/manuals/URC-4021.pdf
Welcome to Remote Central Universal Remote Control Reviews More
Codes for Universal Remotes
Aug 24, 2016 | One For All URC-4021 Remote Control
How do u unlock how sanyo lcd-32ca9s tv without the remote
why did you put a lock on it . and remotes do not have legs to get up and hide from us .universal replacements can be purchased every day of the week for under 20.00
Jan 17, 2016 | Sanyo Televison & Video
Want to used urc-7110 universal remote
If you are looking to use the universal remote for a TV, DVD, VCR, etc ... simply indicate which device (brand, model, etc.) you wish to have a code for. For instance, ask for the code for your Sony HDTV
Dec 26, 2013 | One For All Televison & Video
URC 7110 key functions
you can download another remote control and get some idea
go www.fitness.manualsonline.com
God bless you
Jan 29, 2013 | One For All Televison & Video
Codes for Sanyo HDtv
Hello
Setup code for Sanyo TV with one for all URC-3021 remote control is:
0154
The other four digit codes to check with Sanyo TV with universal remote control are:
0049 0097 0110 0004 0268 0012 0108 0180
OK.
Sep 12, 2011 | One For All URC-3021 Remote Control
Need a code for remote control for a sanyo TV
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sanyo TVs is: 0154.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 27, 2010 | One For All URC-3021 Remote Control
I.Needs the codes for remote control one for all model URC 3220 to work at Sanyo Plasma Tv
I can help you to program your One for All Big Easy URC-3220 Universal Remote for your Sanyo Plasma TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Jan 28, 2010 | Sanyo DP32746 32 in. LCD Television
I need the code for urc3220 remote sanyo tv
I can help you with your URC-3220 Universal Remote Control issues.
The codes for Sanyo TV's are: 0154 & 0159.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Dec 30, 2009 | GE JASRM24912 Remote Control
How do you key in the code for the TV on a URC-3220 remote for a Sanyo TV?
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sanyo TV.
I hope that helps.
May 14, 2009 | One For All URC-3021 Remote Control
Codes lost for one4all
I NEED CODE FOR PHILIPS DVD PLAYER
Feb 14, 2008 | One For All URC-1030 Remote Control
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
