Question about Karcher Garden
We have a Katcher HDS 3.5/30-4 M Ea. Was using it, stopped using it briefly in the middle of a job, pulled trigger again, and there was a lack of pressure. Went to the machine to troubleshoot. The "engine indicator light" is on. Checked the temperature of machine: fine. Water intake: fine. We have not been running it at high temperatures, but about 50 degrees C. The pressure was at about 2300 PSI before it stopped. Any ideas?
3 Suggested Answers
  • 12 Answers
SOURCE: Pressure is fine when first started ,if trigger released no Psi
Your uplift injector valve in the water pump is sticking. You need to remove this part. Lube the top o-ring only with a water proof grease. Reinstall this part. You will be up and running again.
You need to use needle nose vise grip tool to easily remove the valve. You need to grind down the vise grip tool to fit the opening where the valve is installed.
To prevent this problem from reoccuring use a pump guard additive.
Posted on Apr 06, 2009
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
When the trigger is off the motor stops and starts in quick succession until the trigger is pulled again
When the trigger is off your pump is overloading your engine this would be because the unloader is not doing its job try and change the pressure output of the pump this may unstick the unloader if not it may have to be taken apart.
Feb 04, 2011 | Karcher Garden
Doesn't shoot. makes the noise, but no nail comes out. Right in the middle of a job, suddenly the gun stopped working. Pull the trigger, air leaks out. Let go, and it sounds like it shot a nail,...
I have had this problem myself, the only fix is a rebuild kit which you can pick up pretty cheap on ebay. the kit will consist of a bunch of seals and just pay attention to the way you take it apart and you will have no problems
Jul 31, 2010 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Saw stopped working during a job How to troublwshoot a trigger switch on circular saw
when you pull the trigger switch it should "click" when engaged.. if you don't hear a "click" then you have to replace the trigger.... If it does click then it could be brushes, or a short in the cord.
Jun 18, 2010 | Craftsman Saws
Shuts off when high pressure wand is attached
Hi Brian. Welcome to FixYa I am Kelly. This sounds as if the bypass / unloader valve is stuck in place and the pump id dead heading causing the unit to shut off. (There is most likely some corrosion in the unloader / bypassy valve assy / housing. What you can try is pouring at least 3 oz of oil into the water inlet assy and briefly.... like VERY briefly switch the unit on then back off. Then let it sit over night. The next day connect everything for normal use then turn the unit on again briefly. Use a bucket to PURGE the oil that you put through the system by squeezing the wand Power SW Off until the oil purges. Then switch the unit on and rapidly trip the trigger at 0.5 sec intervals or less. If it trips off wait 5 mins and try it again. Do the rapidly tripping the trigger on the wand routine for about 20 seconds. Your forcing the bypass unloader valve to cycle trying to clear out any debris / corrosion.
This works often and well. There are exceptions. Hopefully it will work for you.
Thanks for using FixYa.
Kelly
May 07, 2010 | McCulloch FHH18A Electric Pressure Washer
My dyson dc 16 hand held vacume stops & starts while in use, each time you pull the trigger it will start again but then stops after a short while untill i pull the trigger again.
Cutting out can be due to a few things , motor overheating due to dirty filter, Faulty mains cable or plug..sealed type also..Faulty Switch/trigger.May need to seek pro help to fix.
Apr 01, 2010 | Vacuums
I have a Ryobi RE175. It just stopped working
1. Shut the power off, and disconnect your Ryobi
router. It could be the start/stop switch. So, you
can begin checking the switch contacts using the
multi-tester. Set if at 1 x 10 Ohms. Put the probes
of the tester across the switch terminals. Pressing
the trigger on will move the tester indicator to zero
if your switch is okey. Otherwise, no moverment -
the trigger switch need replacement.
2. Should the trigger switch proved to be okey, Check
the carbon brush of the unit, short carbon brush??
you have to replace it.
Nov 03, 2009 | Electrical Supplies
Middle of print job - stops to CLEAN - then starts from pg1 AGAIN
This is a simple 3 step fix
a) Get rid of printer
b) Get rid of husband
c) Get new printer
Hope this works!! :-)
Jul 16, 2009 | Brother MFC 210C All-In-One InkJet Printer
Ps3 will not play discs
You will need the laser replaced.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Garden Logo
41 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
