Question about Homelite Garden
Checking oil dipstick homelite pressure washer
3 Suggested Answers
  • 57 Answers
SOURCE: How much oil do I
you fill the oil up to the dipstick hole,just so it doesn't over flow out.
Posted on Dec 20, 2010
biggn316
  • 16 Answers
SOURCE: what type of oil to use
for the motor you need to go by manufacturer's recommendation most pumps use 30w non-detergent oil with the dip stick screwed in
Posted on Oct 17, 2012
What oil viscosity and how much on my simpson pressure washer msv 3024
Here's a link to your Simpson manual:
http://simpsoncleaning.com/wp-content/uploads/2016/manuals/megashot/MSV3024-I-pwmanual-7107460.pdf
No oil is required for the pump.
10W-30 is normally specified for a Honda GCV160-GCV190 engine. You drain the oil by removing the oil cap/dipstick and then tilting the machine on it's side so that the oil can drain out if the oil fill into a container. (Drain when warm so it flows easily).
The capacity of the engine is ~18.6 oz. Refill amount is ~12.0-13.5 oz. (either engine).
When refilling, add oil and check on dipstick often. To check, press the dipstick into the oil fill, but DO NOT SCREW IT DOWN. Just insert the dipstick in until it contacts the top of the oil fill. The correct reading is between the lower and upper limits marked on the dipstick. (You may have to look carefully to see the marks).
Dec 27, 2015 | Simpson Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Homelite Pressure Washer. 2700 psi 2.3 GPM Gas Pressure Washer won't start
I found a small long spring disconnected from my throttle which made the engine run rough It is easy to reconnect and makes a big difference in engine performance. also, if there is a very dirty air filter-oil/dirt it will not start-replace filter.
Jun 17, 2014 | Homelite Pressure Washer. 2700 psi 2.3 GPM...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Where is the oil drain plug located on a Homelite 2700 psi 2.3 GPM Honda Gas Pressure Washer?
There is drain plug, surprisingly. You basically have to tip the washer over to the side opposite of the exhaust. I like to take the wheel off first. It is much easier this way. You don't want oil to get in the exhaust Or you could get something like a turkey baster and pull it out. There isnt much oil in there so it isn't that difficult.
Let me know if you need more assistance.
Travis
Jun 06, 2013 | Homelite Ut80993 Honda Gas Pressure Washer
What type of oil to use
Oct 14, 2012 | Powerwasher 2400psi 2.0gpm Pw2420 Gas...
Where is the drain plug for engine oil on Work Force Pressure washer WF 80710
i cant find one so i sucked as much out from the dipstick/fill plug and replaced with new
Jun 14, 2012 | Homelite Workforce 2500 PSI 23 GPM Axial...
How to check oil on honda gx160
There is an oil dipstick on the side of the engine. Remove the dipstick and check the oil on the dipstick.
The oil should be about half way up the threads on this engine.
If you need to add oil you can use SAE 30 or a 10W30 Oil.
Mar 28, 2012 | Garden
How do I change oil to pressure washer?
at the bottom of engine you will notice a plug take it out and oil will draine out .... replce it then fill at top where u see oil dipstick
Jan 19, 2011 | Karcher 2500 PSI Pressure Washer
Garden Logo
47 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
