Question about JVC HD-52G786 52" Rear Projection HDTV
When trying to watch the t.v. using cable input, it says the signal is two weak.
    Top Expert:
  • JVC Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Posted on Jul 31, 2013
  • malcolm hough
    malcolm hough May 27, 2014
    i am experiencing these problems and dpo not have the remote from this model C97 ,what can i do ,besides wait untill i can find one,im trying with the menu and using keys but im getting same thing week signasl when i plug in HDMI and do i have to be on channel 03 for the box to work?
  • malcolm hough
    where is the reset on the back or side control i dont see it on the side
ERROR MESSAGE NO SIGNAL INPUT
What is your TV signal source? Press the Input button on the remote and try another input. (Make sure a DVD player or set-top box is on.) If you are on the TV input, try a different channel. Next make sure that your cables are securely connected to the TV and devices. Replace with new cables to test them. If you use an OTA antenna with a splitter, try a direct connection. (Similarly, if you have an amplifier on the signal, try a connection without the amplifier.)
For OTA or direct cable connections, try accessing the Channel Setup menu and rescanning for channels.
I hope this helps.
(I get some weak channels that give No Signal messages when the transmitter has a problem or the weather is bad. I've also had a signal splitter/amplifier fail and block specific channels by becoming a filter. The direct connection identified the amplifier problem.)
Mar 06, 2013 | Sony KDL-40VE5 40" HDTV LCD TV
Our jvc tv model #HD-70GC78AAA says weak signal
Its possible its the signal source (cable, satellite etc) if using the coax input--the tuner in the set could even be bad.
If rear inputs for DVD etc function well you may be able to get around this with a box with outputs for those inputs on the set--bypass the problem.
Dec 16, 2012 | Televison & Video
Channels out of balance - remote will only change left channel.
switch input cables and try this will confirm if the amp has a problem or the input signal
Jun 19, 2010 | Krell KAV400Xi Amplifier
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
No signal weak signal on only and both component inputs
Sounds like something isn't connected securely inside. Go back and recheck your cables, particularly the DVI cable. Report back if this doesn't solve your problem and we'll try something else.
May 08, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV says "no signal"
my tv says no signal when the cable is plugged in and i have tried scannning it but it says no service found ... what can i do
Feb 16, 2009 | Vizio GV42L 42 in. LCD Television
Screen shows no signal
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Dec 29, 2008 | Polaroid FLM-3732 Television
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
JVC HD-52G786 52" Rear Projection HDTV Logo
114 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
