Question about Bosch Coffee Makers & Espresso Machines
Descaling Nespresso pixie - Bosch Coffee Makers & Espresso Machines
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
espressonist
  • 1711 Answers
SOURCE: I want to know if my Nespresso Pixie D60 has a fuse protection because i plugged my 120 volt 60hz machine into a 220 volt 50 hz power supply without a converter.has my nespresso completely burnt and r
There is not a fuse for protection from this insitent. However the damage on your machine is deoent from how long you left it on with 220v. It can be damage full but it can also not hapent anything. Have you check it again with 120V, since there is a chance that it can still work normal but in any case if not working you may need only a small repair by an eperience percon.
Posted on Sep 23, 2012
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
My nespresso c190 makes coffee watery
Have you decalcified the machine? They need descaling about once every year - 18 months, and one MUST use the Nespresso Descaling Pack, which is designed for all Nespresso machines. I can't understand why the capsule holder is tight, unless you have used so-called "Nespresso Compatible" capsules, which can cause this. The machines are designed for use only with genuine Nespresso capsules.
Feb 28, 2015 | Nespresso C190 Espresso Machine
How do I repair a Teflon tube on NESPRESSO Pixie COFFE MACHINE
You purchase the correct tube as a spare part from a supplier. Give your model to Nespresso and ask for direction.
Dec 20, 2014 | Frontgate Nespresso Pixie Brown Machine -...
My romeo nespresso wont leave the descaling mode
"DESCALING" is not a "mode." When the display says "DESCALING," it means that it needs descaling. Follow the directions in your instruction manual.
Jul 20, 2014 | Nespresso Romeo E350 Espresso Machine
Nespresso d300 appears tap close and does not brew
It probably need descaling. However, if no water comes out at all, descaling is a bit hard. You may need to take out the pump and dip it in vinegar or another descaling fluid.
May 19, 2014 | Nespresso D300 Espresso Machine
Nespresso pixie c60 cup stuck
Can't make the coffee and can't open the lever of pixie nespresso machine
Feb 10, 2013 | Nespresso C60 Pixie Electric Titan Single...
Very slow water flow, barely filling tea cup
It could be a problem with an air bubble or with scale deposits.
It is recommended that you first run a descaling cycle using the proper descaling product. Do not use vinegar as it can damage your machine. Information on descaling can be found here:
http://www.nespresso.com/fileadmin/shared/_img/manuals/Nes_DescalingKit_CBU_internet_081216.pdf
To find more help with your product go to the website below:
http://www.nespresso.com/#/no/en/coffee_machines/selecteur_gamme/machines-le-cube/le-cube-nespresso-auto-d180---110-v-1
Feb 28, 2011 | Nespresso Le Cube
Cleaning nespresso d290
THE MANUAL TELLS YOU NOT TO USE VINEGAR ON THESE MACHINES. THEY HAVE A DESCALING KIT THAT WILL REMOVE THE HARD WATER LIME BUILD UP. LOOK UP NESPRESSO DESCALING KIT AT NESPRESSO.COM
Jan 13, 2010 | Nespresso D290 Espresso Machine
After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
May 16, 2009 | Nespresso D290 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Bosch Coffee Makers & Espresso Machines Experts
Tre Elkins
graybeard32301
Kolbrun...
Are you a Bosch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
