Question about Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens...
Moen kitchen faucet hot and cold reversed - Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens...
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Posted on Dec 29, 2009
Clip will not come loose from kitchen facent moen 7100 to remove carttridge
If you didn't open the faucet to relieve the pressure, the cartridge is pushing up against the clip. Making sure that the valves under the kitchen sink are closed, and open the faucet to relieve the pressure. There is usually a hole at the end of the clip which you can stick an awl into to help removal. Good luck!
P.S. Make sure to note which side of the brass spindle has the notch on it. It should be either facing you, or it should face away. If you put it in wrong, you will reverse the hot and cold. If this happens, simply remove the handle and rotate the spindle 180 degrees to reverse it back.
Jul 01, 2017 | Moen Plumbing
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Moen single faucet extreme temperatures
    The solution is to reverse the connections to the faucet.
    Mar 20, 2015 | Moen Plumbing
    Faucet handle turns wrong way
    You bought two cold water faucets. The threads are reverse on the hot water faucet. Exchange the wrong one at the store you bought it from.
    Dec 31, 2012 | Moen Plumbing
    We are trying to find a re build kit to rebuild the faucet and switch the cartridge to have hot and cold on the proper side. Also how to rebuild the faucet when its fixed
    You get the rebuild kit FREE from Moen, they will ship it to your door.
    The hot and cold is a hook up issue and not resolved in the cartridge. Just switch the input hoses. Sometimes the faucet is actually installed 180 degrees out and causes the same condition. I presume that it worked okay, except the reversal of the water... so switch the hoses.
    Oct 11, 2010 | Moen 7310 Legend Single-Handle Kitchen...
    Moen single handle kitchen faucet, Hot water and
    Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Low hot water pressure in kitchen faucet
    I have moen kitchen faucet # 7560 and water pressure very low. What should I do? We check water flow in pipe it is ok. I changed cartridge as well as pipe nothing help. Please let me know. thanks
    Oct 14, 2009 | Moen & Replacement Cartridge
    I have very little water press on the hot water side
    Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
    You will robably find contamination in the hot side of the valve.
    You can find instructions on the Moen website.
    Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
    Moen kitchen faucet. I changed the cartridge but
    Single or dual lever? A new ball if single lever. Home Depot or Menards will carry them. Teflon tape if dual cartridge. Stay away from moving parts
    Aug 14, 2009 | Moen & One Handle Tub & Shower Faucet
    Hot water on cold side when first turned on moen 7600 series
    did you replace the faucet cartridge??
    if you did, you need to take it out and turn it 180 degree (not head to toe). the water control is on reverse.
    Nov 16, 2008 | Moen 7437 Chateau Single Hole Kitchen...
    Moen 87555C Trianna Single Handle Pulldown Kitchen Faucet with Soap Dispens... Logo
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
