Question about Minolta Office Equipment & Supplies
The paper is jamming at the paper feed - Minolta Office Equipment & Supplies
  • Minolta Master
  • 6,161 Answers
What model machine sir/mam?
Posted on Jan 30, 2015
RPFinney
  • 385 Answers
SOURCE: HP 6200 all-in-one --paper jam problem
Check side ADF grips are correctly setup, paper tray is not mis-aligned, remove if poss, and replace to check.
check you printer's properties paper size is set correct for the paper used,
open the back door check for loose particles or paper,
remove slowly.
4 x Feed rollers in the back, revolve and clean with distilled water.
wait till dry, try printing again
Disconnect the power cord from the product.
Press and hold # and 3 while reconnecting the power cord.
When reset displays, release both buttons.
Try printing again.
Hope this helps
Regards.
Posted on Apr 16, 2009
  • 5 Answers
SOURCE: paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Posted on Oct 16, 2009
pineworks
  • 4041 Answers
SOURCE: paper won't feed through canon printer. no paper jam apparent -
Hello there gave it a go this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 16, 2010
  • 34 Answers
SOURCE: I have this hp laserjet 1300 and it always goes on
see it this site problem solved simple way
http://cluetechnologies.com/index.php?topic=689.0
Posted on Jul 01, 2010
SOURCE: Paper wont feed into printer no paper jam
In the comments section Blumm suggests pushing a piece of cardboard (like the back of a legal pad) through the feeder as far as you can. Turn the printer off and then on again with it in there. Pull the cardboard out and check for any foreign objects that have been pushed through.
It worked for many people including myself - I got a piece of plastic and it works wonderfully again!
Posted on Jul 31, 2010
It wont feed the paper it keeps say paper jam but the paper is not even going in
Lexmark Impact S301 Printer won't take the paper -
printersquestions.com/lexmark-impact-s301-printer-wont-take-the-paper....
Dec 19, 2013 - Feeding paper is the first step of printing materials. However, what will you do when the Lexmark Impact S301 Printer won't take the paper ...
Paper Jam Troubleshooting on 2009 Printers - Lexmark
support.lexmark.com/index?pmv=print&page...en...
LexmarkLexmark Impact S301, Lexmark Impact S302, Lexmark Impact S305 ... When troubleshooting paper jams on Lemark's 2009 printer models, make sure you also ...
[PDF]Solving paper feed problems - Lexmark
www.lexmark.com/publications/pdfs/w820/eng/prfedprb.pdf
LexmarkUse the following table to find solutions to paper feed problems you are ... For detailed instructions on clearing paper jams, see Clearing print media jams.Missing: impact ‎s301
How To: Clear a Paper Jam on a Top Feeding Lexmark ...
? 2:30
https://www.youtube.com/watch?v=H1-J1xDbDsY
Jan 14, 2016 | Lexmark Impact S301 Wireless All-in-one...
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
My 1900 printer power is on and flashing slowly and the paper/garbage light is on and not flashing.
Hello.
You most likely have a paper jam or a paper feeding problem. Paper may have jammed in the sheet feeder, manual feed slot, or roll paper slot.
Sheet Feeder or Manual Feed Slot: Press the
paper button to eject any jammed sheets, then open
the printer cover and remove any paper jammed inside.
Press the paper button again to clear the error.
Hope this helps.
May 31, 2010 | Office Equipment & Supplies
Paper jam indication, but cannot find the paper that is jammed
I would check to see if the paper is even making it out of the tray. A lot of times, the feed rollers can get dirty, and the printer will display a jam if it doesn't feed in time. If the feed rollers look ok, then I would check and see if the feed rollers are even turning. Sometimes the motor that turns the feed rollers wears out.
Nov 11, 2008 | Ricoh Aficio CL7200 Laser Printer
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Paper jam
One of your jam sensors may be stuck in the actuated position by a paper scrap or dust, giving a jam code to your printer. There are usually two sensors, one where the paper feeds, and one where the paper exits. Try this: hand-feed a sheet of paper through the machines paper path,IN THE DIRECTION THE PAPER NORMALLY FEEDS. This may force out whatever is actuating the sensors.
Aug 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Doesn't Print - Says "Paper Jam"
That is the problem, machine will show printer jam if paper feed rollers fail to pick up paper when requested, your machine sounds like it needs new paper feed roller or you can clean the paper feed roller with a slightly! damp cloth.
If no jam light shows when power is turn on and machine comes to ready and then you send a job to printer and it then shows jam then it is the feed roller or sometimes the feed clutch
If on the other hand it always show jam then there is or a switch is stuck.
Oct 25, 2007 | Kyocera Mita FS 1200N Laser Printer
Paper Jams
Depends where the paper is stopping. The fact it is feeding suggests that a sensor isn't stuck, most likely worn out feed, pickup and seperation rollers.
Aug 31, 2007 | Canon NP 6545 Copier
21 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
