Question about Craftsman Garden
Craftsman weedwacker Model No. 316.794400 head not turning but motor running. Do I need to add grease to shaft? If so, what kind and where?
  • 246 Answers
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
SOURCE: I have Craftsman 17" Weedwacker and need fuel lines
Hey jncsurf, I had to buy fuel lines last week. I called the local sears parts store, and gave them the model number. They had a rather generic bag with the correct diameter lines. Just cut to the approximate length.
But now I have a problem: I didn't note which lines went where when I pulled the lines off. Could you tell me where does the line from the primer bulb go: top or bottom barb on the carb? Thanx.
Posted on Jun 22, 2009
SOURCE: Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
Posted on Aug 28, 2009
  • 13735 Answers
SOURCE: who sells craftsman parts besides sears?
check with any place that carries or repairs small engine or farm equipment call or bring model number they can cross reference the part number for other comparable parts some parts are craftsman only and they will be able to tell u also a lot of online companies carry many parts also
Posted on Oct 01, 2009
Testimonial: "Thank you!"
  • 3 Answers
SOURCE: Craftsman model 358.791042, gasoline weedwacker wont stay running
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Posted on Aug 18, 2010
Barely used weed wacker head stopped turning clutch seams loose has play can i unscrew the clutch?allen wrench??
If your clutch is spinning you more than likely have broken the drive shaft that goes down to the head. it is fairly common with craftsman weed trimmers.
Nov 06, 2015 | Garden
While trimming a type of brush wrapped around the cutting head and made the unit stall, upon clearing it the head now is weak and does not spin with enough power to cut; how can i fix this?
Remove string cap and tighten nut or you will have to hold shaft just above string head with pliers and turn head by hand till tight.
press the helpful button and check link below
Craftsman 17 25cc Weedwacker
Sep 15, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Not sure what you mean but if you are saying the weedwacker head is not engaging it may be the cable that goes from the motor to the weedwacker head and runs down the inside of the shaft.
May 24, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Stay running
The carburetor needs to be adjusted very slightly, with a special tool. If still under warranty bring it to the Sears repair center quickly before you damage the engine.
Jul 07, 2013 | Craftsman 29cc 4Cycle Straight Shaft...
My weed starts easily but the cutting head will not rotate
you need to check and make sure the head is installed right ,, if it is sounds like you need shaft and see whats not turning and replace,, hope this help
Jul 06, 2013 | Craftsman 27cc 2 Cycle Crank Straight...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Garden Logo
246 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
