Rex rotary mp c1500sp used ink tank B full error
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
Posted on Jun 23, 2008
  • 37 Answers
SOURCE: REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Posted on Aug 14, 2008
SOURCE: "used ink tank is full"???
OK, Boys and Girls...here finally is the complete answer to the problem of the waste ink tank counter reset for Canon i250 and i350 printers.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
You May Thank Me NOW!!!!
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
I'm not sure how much life this will add to your printer.
Good Luck
Posted on Sep 26, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Waste ink tank full on a Ricoh Africio MP C1500 sp
The book doesn't really tell you where it is in the machine but if you open the door in front of the copier, look for a white plastic bottle with toner in. Remove the toner bottle from the machine and dispose of the toner bottle and replace it with a new one or dispose of the waste toner. Clean the bottle and replace it back into the machine.
Posted on Dec 02, 2008
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Rex rotary MP 4500 how to delete a stored fax which is causeing a paper jam every time it trys to print
It's not the received fax that's causing the problem. There is a problem with the machine, that will cause anything else to jam too. Call for service
Aug 14, 2009 | Office Equipment & Supplies
Rex.Rotary MP 2510
ricoh ft 5832 is not a digital copier therefore cannot connect
May 02, 2009 | Ricoh FT5832 Copier
Error SC320 on Rex Rotary 2822 (Aficio 220)
That is a "Laser motor" Error - Laser motor is dead, and needs replacement.
Apr 30, 2009 | Office Equipment & Supplies
Ink absober is full error 2 and 7 canon MP 160
it looks like you will need to take to a service center to get it replaced. You probably have used your machine a lot and the waste pads are full.
Apr 17, 2009 | Office Equipment & Supplies
Ricoh rex rotary sc 548
Hello wajidsn
Jan 07, 2009 | Ricoh Aficio 450 Copier
Aug 19, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
k24674
jasbo
jasbo
