Question about Vacuums
How do i stop the CAIXING CX-819 ALARM CLOCK FROM GOING OFF EVERY HOUR ON THE HOUR?
2 Suggested Answers
SOURCE: I bought a Caixing CX-2158 led digital clock in
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Posted on Dec 27, 2010
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I have just purchased a second hand AWA CRD176X CD Clock radio that did not come with a manual and I am having trouble setting the time, alarm time etc. Can you please help out at all. Thanks in...
Hi Chris, is this the one?
Like most of this type, it should have a button named TIME, and another one named ALARM.
Then there should be one button named HOUR, and another one named MINUTE.
With the radio turned off, press and hold the TIME button, then tap the HOUR button until you reach the current hour, AM or PM.
Release the TIME button.
Press and hold the TIME button again, and tap the MINUTE button until you see the correct minutes.
Now repeat the same operation with the ALARM button, to set the time the buzzer or music should come on.
If you have any further questions please email me.
Subject: AWA CRD176X CD Clock radio
faxmando@yahoo.com
I can't make out the names of the buttons or functions from my image, so if you need any extra information, please send me a clear image of the top and front of the radio.
Thanks!
Jerry
May 30, 2011 | Vacuums
I have a digital alarm clock from Next - it has the followin gfeatures a mode button - none of the options include time or hour etc an alarm on/off button a button with plus at the top and minus at...
Hi Karen,
Sounds like a neat clock!
I can't find anything about this clock. Other projection clocks set the time change automatically. What happens when you try to push the + button. Does it set the time ahead?
Also, what does it do when you press "kight"?
Karen, if I can't help you with this, please post again to let someone else have a try.
Please write back and let me know what happens with these buttons.
Good luck,
Handie Andie
Mar 27, 2011 | Vacuums
I can not get alarm to work on Constant elite colour change LCD alarm clock
Underneath clock there is 4 buttons, 2 of which are marked (m) & (s) and the other 2 buttons marked with arrows for (up) & (down). depending if you have the clock, alarm or date showing press down on the (s) button for about 3 seconds and the hour digit will start flashing, use the (up) & (down) arrows to set your hour. Then press the (s) button again just briefly and the minute digit will flash and use arrow (up) & (down) buttons to set this also. Press the (s) button again and all will stop flashing and Alarm or Time or Date will be set. Hope this helps as i had same problem but figured it all out in about 2 minutes as i couldn't find my manual lol,.
Jan 27, 2011 | Vacuums
I dropped my battery operated alarm clock: the second hand still works but the alarm doesn't come on at the set time and the hour & minute hands don't "hold" their position - I took the clear...
The hour and minute hands can be pushed onto their respective shafts at any point in most clocks.
If you already know the time that the alarm is set, let the clock run until it sounds.
When the alarm sounds, install the hour hand and the minute hand to the exact alarm set time. If, say, the alarm is set for 6:30, push the hour hand onto it's shaft at exactly half way between 6 and 7 and then push the minute hand onto it's shaft pointing at exactly 6.
I think this should get you operating.
Gary
Jan 16, 2011 | Vacuums
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
Jul 12, 2010 | Vacuums
I'm using my dad's old Panasonic RC-6064 alarm clock. How do I set the time and the alarm?
The Hour/Minute buttons are on the bottom of the radio. Just press the hour or minute buttons to adjust the regular time. Alarm is the same but you hold the alarm button on top.
May 18, 2010 | Vacuums
Vacuums Logo
684 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
