Question about Motorola Wireless Switches RFS-4011-11110-US
How can i reset the RFS-4011-11110-EU to factory defaults? The reset Button doesn't work ...
Motorola rfs6000 default password
Motorola RFS Default Password
Default Ip address ==> 10.1.1.100
Username ==> admin
Password ==> superuser
for CLI==> RFS6000login ==> CLI
Mar 27, 2012 | Motorola RFS6000 Wireless Switch - P/N...
Need the security key password for wireless linksys WRT54G router.mine don't work
The default username and password are as follows:
username: (leave blank)
password: admin
If that doesn't work, you can factory restore the router by doing the following:
1. Unplug the router
2. Hold in the reset button for 30 seconds
3. Plug the router back in and continue holding in the reset button for another 30 seconds
Note that this will reset all of your router's settings to default and you will lose any of the stored settings you have, but it will reset the password to the default I listed above. Hope this helps!
Aug 26, 2011 | Linksys WRT54G2 Wireless Router
Whenever I print my document, it doesn't exist the document I want to print but many strange symbols appear on the printed paper, how can I solve this problem?
Cold reset
A cold reset changes most system parameters in NVRAM to the factory defaults. However, unlike NVRAM inititialization, a cold reset does not reset the page count, the paper tray sizes, language, or formatter number.
Note If an HP Jetdirect card is installed, remove it before performing a cold reset. Otherwise, the procedure will also reset all the HP Jetdirect settings as well as the printer settings.
To perform a cold reset
1 Turn the printer off.
2 Press and hold down the GO button.
3 Turn the printer on, and continue to hold the GO button for at least 5 seconds, but not longer than 15 seconds. During this process, the Attention LED will turn on.
4 Release the GO button.
Note If both the Attention and the Ready LEDs turn on before you release the GO button, you must start the procedure again with step 1.
5 The printer's LEDs will begin cycling. The cold-reset process will
run until completion, and the printer will return to the ready state.
If not work, tris this
NVRAM initialization
CAUTION Only perform the following procedure if absolutely necessary.
Performing an NVRAM initialization resets some parameters that cannot be restored later.
NVRAM initialization sets all default variables stored in NVRAM back to factory default values or to a default ROM value, depending on the variable. It also performs a system reset.
NVRAM initialization resets the following:
  • all menu settings to factory default values
  • factory settings such as formatter number, page counts, and factory paper settings
To perform NVRAM initialization
3 Turn the printer on, and continue to hold the GO button for at least 20 seconds. During this process, the GO button, Attention, and Ready LEDs will each turn on.
5 The printer LEDs will begin cycling. The NVRAM-unit process will run until the printer is in the ready state.
Jul 30, 2011 | HP LaserJet 1300 Printer
Belkin security code
Default security code for Belkin router is to leave the password field blank. If this doesn't work, locate the reset button on the back of the router and hold it in for at least 10 seconds. This should restore it to factory defaults.
Jul 16, 2011 | Belkin Basic Wireless Router
User name &password ?
By default, username is blank, password is "admin"
if this doesn't work you will need to reset the router to factory defaults; the reset button is located at the bottom of the router, use a pin size object to press the button for aprox. 5 secs
NOTE: By resetting the router YOU WILL LOOSE previously saved configurations.
good luck
Jun 06, 2011 | Linksys WRT160N Wireless Router
The television stays in closed caption mode regardless of the settings. Is there a way to reset it to factory default
try turning off the caption through the remote of the menu. to reset it to factory settings, go to menu, then settings, then there should be an option to reset the tv. If this doesn't work look through your manual. Sometimes you have to hold the power button for some length of time or the menu button on the tv. if these methods don't work, tell me the model and make of the tv.
May 28, 2011 | Televison & Video
Lost password
By default there is no user name and paswor. So try leaving the user name and password blank. If it doesn't work, reset the router. There should be a reset pinhole or button to bring the router to it's factory settings. After resetting the router, try the default user name and password again.
May 21, 2011 | Proxim SkyLine Wireless Broadband Gateway...
How do I reset my d-link 615 ? Problem is that pppoe is not lit. Hopefully this would fix the connection which was working fine until it stopped.
If unplugging the power and leaving it off for a minute or two doesn't fix your problem you can reset it to the factory default by using a pen to push the reset button on the back. Factory defaults are on the bottom of the router. You will have to change all your settings back to the way they were though.
Apr 12, 2011 | D-Link DIR-615 Wireless Router
Cant load channel sound but no picture
First reset it to factory default: While pressing [VOLUME ( - )] button on the TV, press [MENU] button of the remote control 2 seconds, the self check screen will appear, then Unplug Power to reset.
If doesn’t work, update the software, if still not work, let me know.
May 31, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Motorola Wireless Switches RFS-4011-11110-US Logo
59 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
