Question about Canon BJC 4300 InkJet Printer
Printer does not react to computer
When I go to use my printer I always receive a DLL error code and the computer doesn't react at all.I tried to reinstall the printer but another error code. What can I do.
    Sergeant:
  • 390 Answers
You either have corrupt printer drivers or pc hardware issues. I would turn printer off. Unplug it and leave it off. Now uninstall it completely. Make a back up copy of your printer disc to eliminate it as a cause, and put aside. Now, on your pc run antivirus and antispyware (you should have these alredy!) I recomment avg free for both. Also run a registry repair progrsm like regcure (always do a restore poit save first, and make a backup copy of registry first beforehand. Sometimes registry repair can leasd to more issues and you have to go back to past settings. Now, reinstall printer with the backup disc, not the original and post back to let me know if this helped.
Posted on Aug 31, 2007
SOURCE:
When i started to print it always gets errors ..always appears "cancel printing"..
Possible that there are errors in the software and so needs a reset. So remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 12, 2011 | Computers & Internet
Canon i350 not recognised by any applications
This is quite a long one so be prepared: Assuming you use IE7 on Win XP FIRST: Are you using a Packard Bell machine or do you have "Surfairy" installed? If so you need to remove Surfairy. To see if it is present if you are not sure use the windows search facility to look for surfairy in my computer. It would also be usefull if you could post the exact text (if any) contained within the Script Error window. Second: pen a new notepad session, to be called IE_fix.cmd, and copy/paste the below: regsvr32 urlmon.dll regsvr32 Shdocvw.dll regsvr32 Msjava.dll regsvr32 Actxprxy.dll regsvr32 Oleaut32.dll regsvr32 Mshtml.dll regsvr32 Browseui.dll regsvr32 Shell32.dll regsvr32 Ole32.dll Save the file, then double click IE_fix.cmd and answer the prompts. Ignore any error messages. Reboot and test. If the problem remains follow the method below Start, Run, SFC /Scannow (Have your XP CD Handy. Note that this command does not give feedback on the repairs it makes. The repairs are listed in your Event Logs.) The error may be linked to a missing/corrupt system file in XP that IE 7 exposes. A repair reinstallatiion of XP will fix it, but the above steps are less drastic.
Jul 11, 2007 | Canon i350 InkJet Printer
Lexmark 6100 series error message Prop Res DLL not loaded
Download tatest driver sfrom lexmark and use revo to uninstall first
Sep 30, 2009 | Lexmark X6170 All-In-One InkJet Printer
My printer doesn`t react
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Scanner: Hi there, " Unplug the Scanner cable from the computer. " Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the Scanner. " then you can connect the Scanner and and try to Scan.
Aug 19, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I keep getting error 1-2070
Resolution
Check to see if the required files are present:
  • Go to C:\WINDOWS\system32\kodak. Check for 2 folders "kds_aio5000(for AiO 5000 series printers) and kds_aioesp(for ESP series)
  • Depending on printer model, open kds_aio5000 or kds_aioesp.
    • For kds_espaio it should only have the lib folder. It doesn't have the ekaiowia.dll
  • Inside the lib folder it should have cct.ekpgct, hippo.dll. Both for kds_aio5000 and kds_aioesp.
  • If hippo.dll is missing then try the following:
Option 1: 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 2 Option 2: 1. Insert the Home AiO CD. Go to CD rom drive\printer\scanner 2. Right click on aioscnnr.msi and choose uninstall once this is finished reinstall it by double clicking on the same msi file. 3. Check to see if the scanner files are now present (see above) if not then go to Option 3 Option 3: (manual installation) 1. Go to C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup\printer\scanner or on CDROM drive ..\printer\scanner 2. Open the aioscnnr.cab file then look for the missing file(files needed: cct.ekpgct, hippo.dll, and ekaiowia.dll) Extract the files anywhere on to the computer (Desktop is preferable). 3. Copy the cct.ekpgct, and hippo.dll to C:\WINDOWS\system32\kodak\kds_aio5000\lib 4. Copy the ekaiowia.dll to C:\WINDOWS\system32\kodak\kds_aio5000
Apr 12, 2009 | Kodak ESP 5 Printer
ZEBRA Z140 PRINTER sw error ADDR:0080F298
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Mar 13, 2009 | Zebra Printer 140-751-00000
My problem is I have a printer and I cannot install it because the file wiafdrv.dll on windowsxp home editon cd-rom is needed an do not have one.
Do you have a Lexmark printer? I found this dll file and many of the comments about it relate to Lexmark printer issues. Click the below link and it will download your missing dll file. I searched for "wiafdrv.dll" and there were no hits for this dll, but there was one for the dll file "wiafbdrv.dll". Make sure before clicking the link below, that this is the correctly named dll file you need.
http://www.dll-files.com/dllindex/wiafbdrv.zip?0VFiP0aMgO
Extract this file and place the dll file in the correct location as specified by the error you're receiving.
Mar 04, 2009 | Computers & Internet
Cant install a printer
HP PSC 1410 All-In-One InkJet Printer installation
Sep 22, 2008 | HP PSC 1410 All-In-One InkJet Printer
Compaq A3000 Drivers won't install in Windows XP Home
Ths looks like a not properly removed software. What you can do is to remove the software manually by removing all the files and registry keys. But do this at your own risk. I suggest that you do a backup of your computer first
Nov 24, 2007 | Compaq A3000 All-In-One InkJet Printer
Open Questions:
See all Canon BJC 4300 InkJet Printer Questions
Canon BJC 4300 InkJet Printer Logo
55 people viewed this question
Clive
Clive
old marine
old marine
Ekse
