Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Jumpy picture Bought this set used in 4/07 picture is now jumpy the problem had gone away or was not nearly as bad. Now the picture is shaking it is visible but distracting. Green light on lamp indicator and I have pushed the reset in the past to help eliminate the problem.
    Problem Solver:
  • 24 Answers
Need the digital board
Posted on Sep 03, 2007
2005 chevy astro making heaving shaking and howling noise while driving
spin the drive shaft back an forth, if it has play then its your universal joints, also lift drive shaft up and down near the the bearing and see if there's play there as well.
Apr 22, 2012 | Cars & Trucks
I have a 1991 chevy blazer S10 4x4 was driving on the highway and very bad shaking happend then slowed down for awile.. shaking went away but comes and goes! notice trans fluied coming from both ends of...
You stop using the vehicle NOW
COMMON SENSE
It will have to go to a repair shop
I would suggest a local trans shop, first
It could be a leaking seal,but one trip
down the street, and you could destroy
the drivetrain in a hurry, if your fluids are gone
Apr 26, 2011 | 1991 Chevrolet S-10 Blazer
Picture on my JVC AV 32120 is a little jumpy and has fine horizonal black lines going thru the picture. This happens if I use the cable connection or the RCA plugs connection. If I pound on the top of the...
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Oct 19, 2009 | JVC AV-32120 32" TV
Jumpy picture on tv from
YOU HAVE PUT ANY MAGNETIC PRODUCT NEAR UR TV.CHANGE IT'S POSITION
Sep 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I bought a scratch and dent Whirlpool Cabrio WTW6200SW and during the spin cycle it is shaking real bad and becoming unlevel even with small loads.
I just bought the exact same model this weekend that I found used in the classifieds. The person who sold it to me said it worked, but when I got it home and hooked it up, it did exactly what yours did, even with no laundry in it. It would get to the spin cycle and start banging around violently like it had a brick in it. I even used an electronic level to make sure it wasn't uneven on the floor. From doing a little research on the web, i read that the suspension could have gone faulty. I took it out and set it up in my garage and hooked a hose up to the cold to see it run a small cold water load with the back panel off so I could observe what was going on inside. From what I observed, the suspension springs were sprung and some worse than the others. I am going to order a replacement set from Sears tomorrow and replace them to see if the unbalanced problem goes away. Removing them is a cinch and should take about a half hour to do all four and put everything back together. I will let you know if my unbalance problem goes away.
Aug 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
2002 f250 shake
You have identified the problem when you pulled the drive shaft and the shake was gone. So you know it is between the tranny and the rear end. If it is not the universal joints, then you have a warped drive shaft.
Jun 22, 2009 | 2002 Ford F250 Super Duty SuperCab
VS-45607 Mitsubishi rear projection TV
Oh good, two people. I was getting weary of attempting to slightly change my answer for all the other people who didn't use the "has the same problem" feature. Anyway, the problem both of you have is not too far gone yet, but will get worse if you let it. It's the main capacitors. Maybe not all 21, but probably at least half of the 21 main caps are shot. All should be replaced at any rate. Any shop worth it's salt ought to be able to do this for you for under $400 if you can't do this yourself.
Oct 31, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Jumpy picture
If this set uses a picture tube then your problem may be in the vertical deflection circuit. Also an unstable power supply will cause this problem. Stargazer
Mar 14, 2007 | Zenith C27V36 27" TV
Sound but no picture
his is the vertical circuit going bad. you willl need a repairman for this. unless you can solder? a cost of repair might range around 400.00 good luck :)
Apr 30, 2006 | Panasonic PT-51G53 51" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
143 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
