Question about Amana Refrigerators
Amana afi2538aeb lights will blink on and off on front panel for 5 to 10 min 3or 4 times a day frig seems to work ok
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
  • 401 Answers
SOURCE: Whirlpool frig. Freezer warm, frig seems ok.
Since the temperature is already 40°, the cold control is satisfied and will not run. Thus the freezer will warm up to 40°.
Posted on Jan 06, 2010
  • 185 Answers
SOURCE: High pitch/humming noise from Frigidaire Refrig.
You have to isolate this problem. It could be one of three things. The compressor, the condenser fan motor or the water valve that feeds the ice maker and wtaer dispenser. Also if the high pitch sound is compared to that of a bird then it is definitely the condenser motor. To isolate the problem take the back cover off. LISTEN FOR THE HIGH PITCHED/HUMMING NOISE! Use a flash light and see if you can tell where it is coming from while it is doing the noise. Dont try this unless you know what your doing. Stop the condenser fan blade with the end of a hard object, but stop it gradually. Dont try this cause you might brake/bend the blade. But if you did and the noise stop then you figured out your problem. If not ythen disconnect the water valve. It has to doulble harness wires attached to it. if problem still exisit then it has to come from the compressor. Unless you have a warranty then theres nothing no one can do except change it. $300-400 job easily.
Posted on Mar 27, 2010
  • 414 Answers
SOURCE: Have an Amana 85088 P1109007W
It may be in defrost mode. Look at the temp control on the underside for a hole with no
screw in it that appears to serve no purpose. Using a flathead screwdriver, turn the
mechanism inside the hole, (it is the defrost timer) and see if the unit comes on. If no
luck, then replace the start relay which is located under the plastic cover on the side of
the compressor. It plugs onto the compressor on three pins, if no replacement is available
they make a "universal" start kit for about 8 dollars which plugs onto these pins and has
good instructions. Model and serial number are usually inside the fresh food compartment
on the left side. The appliance parts store should have this item readily available.
Hope this helps :) remember to unplug unit before replacing any parts.
Posted on Jul 18, 2011
  • 139 Answers
SOURCE: power seems to be on,
Try to unplug for 5-10 mins. Then plug back in. Sometimes the compter needs reboot. Just like your unit you contacted this site with. If this dont work i would look at the motherboard. But you need a tech for that. I hope this helps.
Posted on Aug 23, 2011
Furnace kicks on and heats up for 5 min. then will shut down - no flame - main blower will run for a few min and then the whole cycle will start again. flame sensor checked ok with meter at approx 5.0
What is your temperature rise during the 5 minutes it does run? Could be overheating and kicking out on limit switch. Watch the diagnostic light for a code. (3 blinks means this, 4 blinks means that etc.)
Jan 09, 2014 | Amana Heating & Cooling
Afi2538aeb will not cool refridgerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | Amana AFI2538AEB (256 cu ft) Bottom...
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Amana AGR5735QDS. Bake/Broil don't work, Clean/burners do work
Hello- Most problems with todays ranges start after 'self clean', or as most techs call it- 'self destruct'. If control functions normally, the temp can be run up manually by holding button down until it reaches 500deg., then holding it down until it stops and reads 0 or +/- 5,10, etc. This is a temp adj. mode. If it won't adj. or work at all, control is bad. If it works, then twin ignitor failures are not unheard of. Resistance across either ignitor should be above 4 ohms., if not, they have failed. Avoid 'self clean'. Tears electronics up and wastes energy. Use drip pans and try to forsee boil overs. Grandma figured it out a long time ago. Hope this helps. Thanks- ED
Mar 01, 2010 | Amana AGR5735QDS Gas Kitchen Range
I have a Polaroid 37" (flm3732) that makes a loud whineing noise that also sounds like an electrical arc for the first 15 min after turning on. The time period seems to be getting longer as the days go by....
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Mar 11, 2009 | Televison & Video
Amana afd2535deb Frig- freezer works fine but frig doesn't cool
If the compressor didn't come on the freezer wouldn't work at all. The problem is in the inside fan on the fridge side.
Nov 09, 2017 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
Lights are on but nothing else
Checked the switch in the freezer and it was bad. Odd time for it to go out, but it was not working and it would work intermittently if you shook it.
Jun 10, 2008 | Amana ARB8057CSR Bottom Freezer...
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
Refrigerators Logo
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
