Question about Encore ENLTV-FM (EN-LTVFM)
Vmix software is not working in windows 8 - Encore ENLTV-FM (EN-LTVFM)
I upgrade my pc to windows8.So the old software is not working
hi,
it is normal... there a really a few programs existing that continues working after a major OS update !
you have to reinstall them all (those not working)
Mar 20, 2014 | Sony DCR-TRV285E Digital-8 Digital...
I now have a windows 8 how can I get it to work?
Have a look at the original instructions to see which operating system the software will work with. It should also tell you on the installation disc. If it doesn't mention Windows 8 you might have a problem. You can also visit the Microsoft website to see if your version will work with Windows 8. Or go to the help screen on windows and type "software won't run in windows 8".
You can also visit the software makers website to see if they have a solution.
Jan 29, 2014 | Xitel INport Deluxe for PC
Voyetra midi orchestrator
The only Voyetra Midi Orchestra Plus software I can know was written for Windows 3.1 and Windows 95. Thus there are several reasons for it to be incompatible with Windows 8. First, it was a 16-bit software; the most common Windows 8 installs use a 64-bit OS. This means that the OS has undergone a number of major changes. The installers are completely different (format/way of talking to the OS). The DLLs that communicate between the software and the OS have also changed. The drivers for MIDI devices will be totally different in the modern OS.
The documentation for Voyetra Midi Orchestra is available here: http://www.turtlebeach.com/support/files/241/ . It is a discontinued product and no one at the company that owns it will be writing a new version of the code for Windows 8. I'm not sure this software will work in Windows 7 32-bit. You might be able to use the software in a compatibility mode from a virtual version of XP. For Windows 7 Pro, Virtual PC and the XP mode package are available as free downloads and can be used if your hardware allows. Windows 8 Pro has Hyper-V but requires a licensed version of any Windows OS that you want to use. For non-pro versions of Windows software, you would need to buy a Pro upgrade. The alternative is to obtain another Virtual machine software (VMWare, for example) and a licensed copy of XP or an older version of Windows. (OEM Windows 7 Pro licenses are still available from many computer hardware vendors.)
I hope this helps.
(Many 32-bit device drivers don't work under Windows 8; older software that didn't run under Windows 7 have similar problems.)
Nov 29, 2013 | Yamaha Music
WACS700/05 I have a new PC with windows 8. The DMM software (V2.0) doesn't work. Any ideas?
Visit the Windows site to see if the software will run with Windows 8. You can also try running it under the last operating system it worked on. I'm certain Windows 8 will allow this.
Sep 02, 2013 | Audio Players & Recorders
The CD -rom not compatible with windows 8. it works on windows 95
Between Win95 and Windows 8 there are several other versions Win 98, Win 2000, Win XP, Vista, and Windows 7. Try to run the CD in compatibility mode. If it does not work you will have to forgo the use of that software or run it on an old machine, or upgrade to a version compatible with Windows 8 if one such upgrade exists.
Aug 31, 2013 | Expert Software Computers & Internet
Will software for windows 7 work on windows 8
Yes most software and hardware that worked with Windows 7 will work with Windows 8, I would just install it and see if it works.
Dec 30, 2012 | Video Cameras
Need manual for vtech 2434 phone
You may download a copy of the manual here.
Oct 19, 2012 | Vtech VMix Gz2434 Cordless Phone
My v tech phone keeps on saying no connect
mine was showing no connection to base and i put in a new battery
Dec 26, 2011 | Vtech VMix Gz2434 Cordless Phone
Caller can't hear my vocie when I use hand set
probly it fell or something the speaker needs replacing
Jan 04, 2006 | Vtech VMix Gz2456 Cordless Phone
Encore ENLTV-FM (EN-LTVFM) Logo
Top Encore Televison & Video Experts
John Bolton
Tom Chichester
Are you an Encore Televison and Video Expert? Answer questions, earn points and help others
