Question about Fujitsu fi-6770 Flatbed Scanner
Scandall pro My scanner feeds the documents throuhg but the images arent being captured....any soultions?
3 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: scanner not found scandall pro
Unplug the USB cable and delete the software.
Reinstall the software but don't plug the scanner in until the software tells you to.
Posted on Jan 17, 2010
SOURCE: Fi-6130z ScandAll Pro won't close
You probably have Roboform as well.
Launch Roboform. It will open in Internet Explorer. Open the settings option.Under the default proflie window select 'applications integration', then uncheck 'automatically attach to Windows applications'. Reboot your system. The program should now close after scans.
Posted on Mar 21, 2013
Scandall pro
Unchecking the box in RoboForm worked for me! Thanks!
Jul 06, 2013 | Office Equipment & Supplies
Saving appended files in Scandall 21 version 4.3.17
when you are saving the file make sure you are saving the file in the desired format ... the save as type option.
Jul 14, 2008 | Computers & Internet
Aug 26, 2012 | Fujitsu fi-6130z - Document scanner -...
The scanner is not available while in use by another application or user i get this darn error. I use this scan multiple times a day and all of a sudden i see this.... why?
The error message could be Twain Driver error or ScandAll pro Application error. Please go through the followings:
SCANDALL-PRO APPLICATION ERROR:
Error Code: [SA01020E] No scanner is found.
There is a possibility that no scanner is connected, the connected scanner is not turned on, or the scanner is currently used by some other application.
Status: [Scan] or [Select Scanner] is specified, but no connected scanner is found. Or, the scanner is currently used by some other application.
Action: Make sure that the scanner is connected and is turned on. If the scanner is currently used by some other application, use the scanner after the application ends. Make sure that the driver selected on the [Scan] tab of [Preferences] in the [Tool] menu is installed correctly.
TWAIN DRIVER ERROR:
-The scanner may be OFF or not connected. Check the power supply of the scanner or connection with PC.
-The scanner may be already in use by other application or the "Scanner and Camera" in [Control Panel].Close other application or "Scanner and Camera" in [Control Panel]
-The connected image scanner is not a model supported by this driver. No image scanner is connected. The cable is disconnected.Check whether the image scanner is connected.
-Another application may already be using the image scanner. Alternatively, the TWAIN driver may have been activated twice.Terminate all applications, and start scanning again.
For more information, please refer to the help contents of Scanner utility/Twain driver and scanning application installed on your PC.Hope the above information is helpful.
Thanks,
ScanCare
Jun 22, 2012 | Office Equipment & Supplies
Epson S-50/XP-Pro/ twain-approved application will fire the scanner to feed the documents, scan the documents, but will not allow the application's captured-preview window to open.
try using free irfanview and acquire the scanning from there and save or edit the output, once installed just select file, then select twain source and your scanner will be there. Much easier option than scanner software
Feb 26, 2012 | Office Equipment & Supplies
The fujitsu fi-5110C won't scan all pages just takes the whole thing and just scans the first page. Is there a setting where you can make the scanner to scan each page one at a time? thank you :)
Please follow the information provided below:
If all the pages are being fed through ADF and if image format is TIFF, then you may require another application to view the multi page TIFF image. If you're using ScandAll 21 or ScandAll Pro application for scanning, you have to choose multi page scan option in Batch Scan Setting. Please follow the help contents provided in the scanning application.
Hope the above information is helpful. Please revert if you have any doubt.
Regards,
TechSatya
Jun 29, 2010 | Fujitsu fi-5110C ScanMaker Scanner
Getting Error SA010771 for Fujitsu scanner when I press the Scan button
Found it! To fix the SA010771 error.
This assumes you have already sat there (like I did) and tried everything including adding the event in the scanner settings and changing 0 to ScandALL PRO)
Open Scandall Pro click SCAN - Batch Scan Settings - Add a new profile, for the moment just leave everything as is (change it later). Click Close then close ScandALL PRO and then reopen it.
Click TOOL - Preferences - Event tab, you should now be able to select Profile 1 (or whatever you named it) from the dropdown for Scan.
You can figure the rest out from there : )
Jimi@JamesGoethe.com
Nov 16, 2009 | Fujitsu fi-5530C Scanner
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
The documents are scanned but dont appear on later inspection, or if they do they are just a horizontal line across the middle
Try reinstalling the driver software. If the problem still persists, run scandisk or reinstall OS.
S. Mohan
Aug 21, 2008 | Canon DR-9080C Path-Through Scanner
Can't setup ScandAll 21 on fi-5120C
why do you want to use the older version, the new version has much better driver support and actually works with the event buttons on the scanner.
May 23, 2008 | Fujitsu fi-5120C
Fujitsu fi-6770 Flatbed Scanner Logo
32 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
