Question about Nordic Track GX 4.5 Cycle
The eddy mechanism slips while pedaling - Nordic Track GX 4.5 Cycle
My pedal has somehow broken inside and now it spins freely without moving the chain
Being a mechanical problem that we can't see you will need to define it better to us or yourself.
I'm sure if you looked at it closer you would see that the pedal itself is supposed to spin freely while it turns on the crank which turns the chainring which transfers motion through the chain to the gear(s) on the right side of the rear wheel which drive the wheel forward.
Now, where do you think the breakdown really is?
Any search engine would then offer definitions and solutions to a well-crafted query like "bicycle chain slipping" or "bicycle gear slipping".
Aug 15, 2011 | Giant Boulder Se Mountain Bike 19"...
Clutch pedal travel is excessive. Sits about 2"
A clutch pedal takes MUCH more travel to function correctly, when compared to a brake system...
A clutch needs to be replaced (maybe) when it SLIPS, Chatters, Or fails to release...
Other than that, the clutch will need to be adjusted to allow for total release of the relese bearing when pedal is released, and full disengaugement when pedal is depressed....Have a mechanic look at the adjustement, as proper adjustment gives longer clutch life. This is a periodic adjustment item.
Apr 03, 2011 | 2001 Subaru Impreza
I work in a fitness centre and we have schwynn bikes in our spinning studio. Customers keep complaining that some of the bikes are slipping?? Schwynn have assured us it is their technique and they are...
Schwinn may be right in that the spin bikes have a "clutch" on the flywheel that would keep it from causing to much damage to your leg if you slipped off the pedals. Also as the bikes get used these can become worn and require rebuilding, so some bikes wear faster than others so one may seem fine and another slips. Get on the bike pedal forwards and try to stop then you can feel it and see which slip more.
Jan 31, 2010 | Sport & Outdoor - Others
Pedals/resistance locked
Was this at a retail store you should exchage it.
If not then you will have to take the side off need to inspect all mechanical attached to the rails. It will be apparent to see the flywheel their eddy current transformer on top of unit or the flywheel itself is one package their should be are wire comming out of trace it back to the circuit unplug the connectors the resistance should be gone now test the mechanical function of unit to see if the pedal are free from any binding then reverse connectors and see if you can adjust the resistance if not the board is defective.
Jan 04, 2010 | Exercise & Fitness
1994 bronco eddie bauer. I have no brake lights
I think there are 2 switchs on that brake pedal. You are right tho about the brake switch causing your problem.
If you fix your brake light problem your other problem will be fixed also.. check to see if the wires at the brake pedal switch are energized. I am betting on a ground problem.
Dec 22, 2009 | 1994 Ford Bronco
1998/99 Dodge Dakota clutch and manual transmission problems
clutch needing replaced, very common on all manuals
pedal travel adjustment,yes
gear shift adjustment,no
May 12, 2009 | 1998 Dodge Dakota
Clutch slipping
A clutch is usually adjusted from underneath the car if it's a mechanical clutch.
Your comment that there is very little play at the top indicates an improperly adjusted clutch. You should have about 1/2 - 3/4 inch of play before feeling the clutch in the pedal.
Jan 24, 2009 | 2003 Nissan 350Z
Clutch
believe it or not, the floormat on my 2000 Sunfire will sometimes slip forward and hold the clutch pedal down against the floor. It truly feels like a mechanical problem, but simply pull the floormat away and the pedal pops right back up!
Jun 29, 2008 | 2004 Pontiac Sunfire
Nordic Track GX 4.5 Cycle Logo
61 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
